    Python Tag not updating
    9 Posts 3 Posters 1.8k Views 3 Watching
    • SwinnS Offline
      Swinn
      Hi, I have a null with some User Data on it and a Python tag attached to it. When I make changes in the User Data, the Python tag does not seem to see them. If I make a slight change to the Python tag, then it does. Is there a way to get the Python tag to react to User Data changes without modifying it? Thanks.
      • r_giganteR Offline
        r_gigante
        Hi @Swinn, thanks for reaching out us.
        With regard to your issue, please have a look at this thread where it was discussed how to have a python tag reacting to a button userdata assigned to the tag's parent. In your case you might be more interested in parsing the events stream until you encounter a MSG_DESCRIPTION_POSTSETPARAMETER .
        def message(msg_type, data):
            if msg_type == c4d.MSG_NOTIFY_EVENT:
                event_data = data['event_data']
                msg_id = event_data['msg_id']
                if msg_id == c4d.MSG_DESCRIPTION_POSTSETPARAMETER:
                    desc_id = event_data['msg_data']['descid']
                    if desc_id[1].id == 1: # The ID of the User Data
                        print "A little bit more off"
                        mtx =  op.GetObject().GetMg()
                        mtx.off = mtx.off + c4d.Vector(10,0,0)
                        op.GetObject().SetMg(mtx)
            obj = op.GetObject()
            # Check if we already listen for message
            if not obj.FindEventNotification(doc, op, c4d.NOTIFY_EVENT_MESSAGE):
                obj.AddEventNotification(op, c4d.NOTIFY_EVENT_MESSAGE, 0, c4d.BaseContainer())
        Rest to be told that, for some yet-to-understand reason, the Python console doesn't print the text A little bit more off on the user changing the userdata, but this is neglectable if you're interested in the real action that the Python tag executes.
        Best, R
          r_gigante
          With regard to logging-lagging @m_adam has pointed me to this other thread.
          If you rewrite my code as
                          txt = "A little bit more off"
                          pythonLogger = maxon.Loggers.Python()
                          pythonLogger.Write(maxon.TARGETAUDIENCE.ALL, txt, maxon.MAXON_SOURCE_LOCATION(1), maxon.WRITEMETA.UI_SYNC_DRAW)
          you'll be fine to go 🙂
          Cheers, R
          • SwinnS Offline
            Swinn
            Thanks! I will test this out.
            • SwinnS Offline
              Swinn
              @r_gigante said in Python Tag not updating:
              I get an error message Traceback (most recent call last):
              File "Python UD Integration Test", line 11, in message
              NameError: global name 'maxon' is not defined
                import maxon
                • SwinnS Offline
                  Swinn
                  Done. Fixed. Duh on my part. 🙂
                  Thanks!
                  • SwinnS Offline
                    Swinn
                    Now getting this error:
                    File "Python UD Integration Test", line 13, in message
                    File "/Applications/MAXON/Cinema 4D R20/resource/modules/python/libs/python27/maxon/interface.py", line 287, in MAXON_SOURCE_LOCATION
                    return SourceLocation(loc[0], loc[1])
                    File "/Applications/MAXON/Cinema 4D R20/resource/modules/python/libs/python27/maxon/interface.py", line 274, in init
                    Data.init(self, self._dt)
                    File "/Applications/MAXON/Cinema 4D R20/resource/modules/python/libs/python27/maxon/data.py", line 104, in init
                    self._data = Data_Create(self._dt._data, C)
                    TypeError: failed to set member 'file', caused by (exceptions.TypeError: unable to convert maxon.datatype.DataType to @char)
                      make sure to pass a str value aka str(yourMessage)
                      if this doesn't solve the issue open a new topic 🙂
                      Maxime
