    GetWidth() for GeDialog?
    r21python
    4 Posts 2 Posters 446 Views 2 Watching
    • B Offline
      bentraje
      I understand there is GetWidth for GeUserArea.
      Is there also a GetWidth equivalent for GeDialog?
      I have a bunch of images in a grid with 5 colums.
      I want the number of columns to change based on the Width of the GeDialog
      Is there a way around this?
        Hi @bentraje you can retrieve the size of the current window with BFM_ADJUSTSIZE
            def Message(self, msg, result) :
                if msg.GetId() == c4d.BFM_ADJUSTSIZE:
                  print 'x => ' + str(msg[c4d.BFM_ADJUSTSIZE_WIDTH])
                  print 'y => ' + str(msg[c4d.BFM_ADJUSTSIZE_HEIGHT])
                return c4d.gui.GeDialog.Message(self, msg, result)
        Then it's up to you to store the value in a member variable of your class.
        • B Offline
          bentraje
          @m_adam
          Thank you. Works as expected.
          • B Offline
            bentraje
            Hi @m_adam .
            Apologies for bringing up the thread again. I just have a follow up question.
            The def Message works well for the consecutive duration of the dialog.
            But for the initial life (i.e on startup), the def Message will not be executed .
            Is there a way to determine the width and height of the dialog upon its startup?
