    GeUserArea ActivateFading and AdjustColor
    c++r19r20r21
    6 Posts 2 Posters 708 Views 1 Watching
    • C4DSC Offline
      C4DS
      Was wondering how the GeUserArea functions ActivateFading and AdjustColor are supposed to be used. Didn't find any example, nor does the documentation clearly explain when and where the perform the call.
      Does the ActivateFading needs to be called when mouse hovers over the GeUserArea, detected with BFM_GETCURSORINFO in GeUserArea::Message?
      And needs the ActivateFading be called again related to BFM_CURSORINFO_REMOVE?
      Do we then have some kind of "fade in" and "fade out"? Or is there only a single fading?
      How to distinguish between fade in and fade out? Since the AdjustColor sets the blend colorS for fading I assume there is a color to fade in to, and one to fade out to? Or is it fade from - to?
      And then the AdjustColor arguments: an Int32 while the document mentions COLOR. Documentation just leads to an enum when clicking on the link. How to provide an appropriate value?
      What about the float percentage value? Is it between 0.0 and 1.0 or between 0.0 and 100.0?
      "Percentage" doesn't say much.
      So many questions.
      • P Offline
        PluginStudent
        Here is an example: GUI and Interaction Messages Manual
        C4DSC 1 Reply Last reply Reply Quote 1
        • C4DSC Offline
          C4DS @PluginStudent
          @PluginStudent
          Ah, the BFM_FADE message ...
          Thanks for the link.
          • C4DSC Offline
            C4DS
            What if one would want to use a GeClipMap for drawing in the GeUserArea, how to handle the resulting fading? How to access the color components, since the COLOR id used via the AdjustColor can not be used.
            • P Offline
              PluginStudent
              Can you access the color using GeUserArea::GetColorRGB()?
              • C4DSC Offline
                C4DS @PluginStudent
                @PluginStudent
                Yup ... it's official, I need glasses on top of my glasses.
                Thanks for pointing it out.
