    Python script for Rectangle Selection with options
    4 Posts 3 Posters 1.1k Views 1 Watching
    • T Offline
      Tennet
      Hi! I've tried to create a simple Python-script for switching to selections tools using my own "personal" selection settings.. but it doesn't work as I want it to.
      For example, when I select the 'Rectangle selection' tool, then I want "Tolerant Selection" to be checked by default. And 'Only Select visible' should be off.. but it doesn't work. The script doesn't change these settings if they are set to something else before.
      My script looks like this (below). Would really appreciate if someone could help me with the correct code for this (I don't understand programming, I only copy and paste the code from the Script Log..). Or point me in a direction where I can learn it. Many thanks! 🙂
      from c4d import documents, plugins
          c4d.CallCommand(12139) # Points
          c4d.CallCommand(200000084) # Rectangle Selection
          tool()[c4d.MDATA_SELECTION_TOLERANCE] = True
          tool()[c4d.MDATA_SELECTION_VISIBLE] = False
          c4d.EventAdd()()
      • R Offline
        rb_rodrigo
        Hi! always look at the python console to see where its pointing the error. if your code isnt correct it should print something
        here the fixed code.
        please compare them.
        from c4d import gui
        # Main function
        # Execute main()
          you didn't paste the function tool(). As @rb_rodrigo said you should always open the console (shift + F10) and have a look there. You should see something like thisNameError: global name 'tool' is not defined
          showing that you forgot to define the function tool()
              def tool():
                  return c4d.plugins.FindPlugin(doc.GetAction(), c4d.PLUGINTYPE_TOOL)
          your final script should look like this :
          def tool():
          • T Offline
            Tennet
            Hi Manuel and @rb_rodrigo,
            Many thanks for the tips about the Python console and help with the code. I'm a beginner (not even that!) in scripting, so much appreciated. It works as expected now!
            Frederik
