    Check User Data Link Field
    3 Posts 2 Posters 890 Views 1 Watching
    • SwinnS Offline
      Swinn
      Hi, is there a way to use Python to check if there is a link in a User Data field or if it is empty? Thanks.
      • P Offline
        PluginStudent
        What do you mean with "use Python"? Are you writing a script, or a plugin, or something else?
        You can simply access the user data parameter and see if it is None or not:
        link = op[c4d.ID_USERDATA,1]
        if link is None:
            print("no link")
            print("some object linked")
        Also: please post questions on the C4D API in CINEMA 4D DEVELOPMENT.
        SwinnS 1 Reply Last reply Reply Quote 1
        • SwinnS Offline
          Swinn @PluginStudent
          @Swinn is None did the trick. Thanks. 🙂
