    AttributeError: 'GUI' object has no attribute 'AddCheckBox'
    3 Posts 2 Posters 924 Views
    • G Offline
      geese780
      Hey Guys,
      I'm getting the error " AttributeError: 'GUI' object has no attribute 'AddCheckBox' " in my console, and I believe I'm bringing in the right libraries, I think...But, I cannot seem to find anything that's helping searching through forums and the c4d.gui info pages.
      Maxime helped me understand the group concepts so thanks again for that. I commented out a lot of code to test things, but here's the current code that's throwing the error. Still a lot of learning to do, but I've been on this particular error for 2 hours now....oh fun haha
      from c4d import gui, plugins, bitmaps, documents
      class GUI(gui.GeDialog):
          """ Creates the main graphical user interface of the plug-in  """
          ResourceFileGroup = 101
          SettingFilegroup = 102
          Label_Folders = 201
          Label_Settings = 202
          Label_ObjectsImport = 203
          ResourceFolder = 301
          MVRFileLocation = 302
          AllCheckBox = 401
          HangingPosCheckBox = 402
          TrussCheckBox = 403
          FixturesCheckBox = 404
          GeometriesCheckBox = 405
          ComboBox_ID = 1003
          AddChild_1 = 1004
          TextEdit = 1005
          RadioGroup = 1006
          RadioText = 1007
          RadioChild = 1008
          def CreateLayout(self):
              self.SetTitle("My Dialog")
              self.GroupBegin(self.ResourceFileGroup, 0 | 0)
              self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "Source Files", 1)
              self.AddButton(self.ResourceFolder, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "Resource Folder")
              self.AddButton(self.MVRFileLocation, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "MVR File")
              self.GroupEnd()
              self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "Settings", 1)
              self.AddCheckBox(self.AllCheckBox, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "All")
              self.GroupEnd()
              # if self.GroupBegin(self.SettingFilegroup, 0 | 0):
              #     self.AddStaticText(self.TextEdit, 0 | 0, 100, 25, "Settings", 1)
              #     self.AddCheckBox(self.AllCheckBox, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "All")
              # self.GroupEnd()
              # self.SetTitle("CAV MVR IMPORTER")  # Set dialog title
              # self.AddRadioText(self.Label_Folders, c4d.BFH_LEFT | c4d.BFV_TOP, 0, 0, "Source Files")
              # self.AddRadioText(self.Label_Settings, c4d.BFH_CENTER, 0, 0, "Settings")
              # self.AddRadioText(self.Label_Settings, c4d.BFH_RIGHT, 0, 0, "Objects To Import")
              # self.AddButton(self.ResourceFolder, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "Resource Folder")
              # self.AddButton(self.MVRFileLocation, c4d.BFH_LEFT | c4d.BFV_TOP, 125, 25, "MVR File")
              # self.AddComboBox(self.ComboBox_ID, 0 | 0, 100, 25, True, True)
              # self.AddChild(self.ComboBox_ID, self.AddChild_1, "Drop Down 1")
              # self.AddRadioGroup(self.RadioGroup, c4d.BFH_SCALE | c4d.BFV_SCALE, 1, 3)
              # Create a Group, its usefull because here we adds the StaticText Gadget and to make it appears again
              # LayoutChanged needs to be called, which work only a group.
              # if self.GroupBegin(self.TextEditGroup, c4d.BFH_SCALEFIT | c4d.BFV_TOP):
              #     self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "", 1)
              #     self.HideElement(self.TextEdit, True)
              # self.GroupEnd()
          # def Command(self, id, msg):
          #     # RESOURCE FOLDER BUTTON
          #     if id == 201:
          #         fn_ResourceFolder = c4d.storage.LoadDialog()
          #          # Unhides the Text element
          #         self.HideElement(self.TextEdit, False)
          #         # Checks if its a str, then display the file path
          #         if isinstance(fn, str):
          #             # SET THE STRING
          #             self.SetString(self.TextEdit, fn)
          #         # If its not a string, the user cancelled
          #         else:
          #             self.SetString(self.TextEdit, "User cancelled")
          #         # Notify the layout of the group changed, this will invalidate the group and it will be then redraw
          #         # This is needed because the UI was hidden, if the Ui is not hidden then there is no need for it
          #         self.LayoutChanged(self.TextEditGroup)
          #     # MVR FILE BUTTON
          #     if id == 202:
          #         fn_MVRFileLocation = c4d.storage.LoadDialog()
          #             # SET THE STRING
          #         else:
          #         print fn_MVRFileLocation
          # Test dialog
          diag = GUI()
          diag.Open(dlgtype=c4d.DLG_TYPE_MODAL, defaultw=1000, defaulth=400)
      # Execute main()
      Thanks again for any insight.
      Cheers!
      MattG
      • P Offline
        PluginStudent
        According to the docs: AddCheckbox().
        Not "AddCheckBox()"
        • G Offline
          geese780
          Well Uh.....Yea.....Guess I should take a break......Thanks for the point out of the lower case b........🙄
          This is solved. Thanks Plugin Student!
          Cheers!
          MattG
