    Create a download progress bar in python
    5 Posts 3 Posters 1.7k Views 2 Watching
    • mfersaouiM Offline
      mfersaoui
      I found the following functions on a stackoverflow topic, and I want to apply it on c4d.gui.GeDialog.
      I put more details in the code:
      import urllib2
      def chunk_report(bytes_so_far, chunk_size, total_size):
          percent = float(bytes_so_far) / total_size
          percent = round(percent*100, 2)
          sys.stdout.write("Downloaded %d of %d bytes (%0.2f%%)\r" %
              (bytes_so_far, total_size, percent))
          if bytes_so_far >= total_size:
              sys.stdout.write('\n')
      def chunk_read(response, chunk_size=8192, report_hook=None):
         total_size = response.info().getheader('Content-Length').strip()
         total_size = int(total_size)
         bytes_so_far = 0
         while 1:
            chunk = response.read(chunk_size)
            bytes_so_far += len(chunk)
            if not chunk:
               break
            if report_hook:
              report_hook(bytes_so_far, chunk_size, total_size)
         return bytes_so_far
      class Update(c4d.gui.GeDialog):
          UPDATE_BTN = 1000
          PROGRESS = 1001
          PROGRESSBAR = 1002
          state = ""
          def CreateLayout(self) :
              self.AddButton(self.UPDATE_BTN, flags = c4d.BFH_LEFT, inith = 13, name = "Update")
              self.AddStaticText(self.PROGRESS, flags=c4d.BFH_SCALEFIT, initw=0, inith=0, name=self.state, borderstyle=0)
              # I want take the percentage value from the function chunk_report() and apply it to the following CUSTOMGUI_PROGRESSBARCUSTOMGUI_PROGRESSBAR
              self.GroupBegin(id=0, flags=c4d.BFH_LEFT, cols=1, rows=0)
              self.GroupBorderNoTitle(c4d.BORDER_THIN_IN)
              self.AddCustomGui(self.PROGRESSBAR, c4d.CUSTOMGUI_PROGRESSBAR, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT,200, 8)
              self.GroupEnd()
          def Command(self, id, msg):
              if id == self.UPDATE_BTN :
                  filedata = urllib2.urlopen('https://www.domainname.com/file.zip')
                  chunk_read(filedata, report_hook= chunk_report)
                  self.SetString(self.PROGRESS, "Or showing the write result of chunk_report() function here?") # <---
      mfersaouiM 1 Reply Last reply Reply Quote 0
        mfersaoui @mfersaoui
        I found the solution.
        import urllib2
            UPDATE_BTN = 1000
            PROGRESS = 1001
            PROGRESSBAR = 1002
            state = ""
                # How to taking the percentage value from the function chunk_report() and apply it to the following CUSTOMGUI_PROGRESSBAR
                self.GroupEnd()
            def chunk_read(self, response, chunk_size=8192):
                bytes_so_far = 0
                progressMsg = c4d.BaseContainer(c4d.BFM_SETSTATUSBAR)
                progressMsg[c4d.BFM_STATUSBAR_PROGRESSON] = True
                while 1:
                    if not chunk:
                        break
                    progressMsg[c4d.BFM_STATUSBAR_PROGRESS] = percent/100
                    self.SendMessage(self.PROGRESSBAR, progressMsg)
                    self.SetString(self.PROGRESS, percent)
                    self.chunk_read(filedata)
        • indexofrefractionI Offline
          indexofrefraction
          tx, but how can i use this in a simple scenario?
          it doesnt do anything when pasted into the script manager
            mfersaoui @indexofrefraction
            @indexofrefraction
            Here is a full example that you can test it on script manager:
            # The following code allow to download a file and then save it on the desktop
            import c4d, os, math, urllib2
            from c4d import gui
            PLUGIN_ID = 99999999
            class MyDialog(gui.GeDialog):
                DOWNLOAD = 2000
                CLOSE = 2001
                STATE_GROUP = 2002
                PROGRESSBAR_GROUP = 2003
                PROGRESSBAR = 2004
                PROGRESS_TEXT = 2005
                def InitValues(self):
                    self.HideElement(self.PROGRESSBAR_GROUP, True)
                    self.LayoutChanged(self.STATE_GROUP)
                def StopProgress(self):
                    progressMsg.SetBool(c4d.BFM_STATUSBAR_PROGRESSON, False)
                def CreateLayout(self):
                    self.GroupBegin(0, flags=c4d.BFH_SCALEFIT, rows=1, cols=1)
                    self.SetTitle("File Downloader")
                    self.GroupBegin(0, c4d.BFH_SCALEFIT, cols=3)
                    self.GroupBorderSpace(0, 5, 2, 5)
                    self.AddButton(self.DOWNLOAD, flags = c4d.BFH_LEFT, inith = 13, name = "Download")
                    self.AddButton(self.CLOSE, flags = c4d.BFH_RIGHT, inith = 13, name = "Close")
                    self.GroupEnd()
                    if self.GroupBegin(id=self.STATE_GROUP, flags=c4d.BFH_SCALEFIT, rows=0, title="", cols=2, groupflags=0):
                        self.GroupBegin(self.PROGRESSBAR_GROUP, c4d.BFH_LEFT, cols=2)
                        self.GroupEnd()
                        self.GroupEnd()
                        self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, cols=1, rows=0)
                        self.GroupBorderSpace(8,2,0,0)
                        self.AddStaticText(self.PROGRESS_TEXT, flags=c4d.BFH_SCALEFIT, initw=0, inith=16, name="", borderstyle=0)
                        self.GroupEnd()
                        self.GroupEnd()
                        self.GroupEnd()
                    self.GroupEnd()
                def convert_size(self, size_bytes):
                    if size_bytes == 0:
                       return "0B"
                    size_name = ("B", "KB", "MB", "GB", "TB", "PB", "EB", "ZB", "YB")
                    i = int(math.floor(math.log(size_bytes, 1024)))
                    p = math.pow(1024, i)
                    s = round(size_bytes / p, 2)
                    return "%s %s" % (s, size_name[i])
                    bytes_so_far = 0
                    data = b""
                    while 1:
                        if not chunk:
                            break
                        self.SetString(self.PROGRESS_TEXT, "Downloaded %s of %s bytes (%0.2f%%)\r" % (self.convert_size(bytes_so_far), self.convert_size(total_size), percent))
                        data += chunk
                    return data
                    if id == self.DOWNLOAD:
                        self.HideElement(self.PROGRESSBAR_GROUP, False)
                        # path to save downloaded file on desktop
                        write_path = os.path.join(c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP), 'zip_9MB.zip')
                        response = urllib2.urlopen('https://file-examples.com/wp-content/uploads/2017/02/zip_9MB.zip')
                        datatowrite = self.chunk_read(response)
                        with open(write_path, 'wb') as f:
                            f.write(datatowrite)
                        self.SetString(self.PROGRESS_TEXT, "")
                        self.StopProgress()
                    if id == self.CLOSE:
                        self.Close()
                Dlg = MyDialog()
                Dlg.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID, defaultw=500, defaulth=120)
              @indexofrefraction and just in case you have this example from CUSTOMGUI_PROGRESSBAR if you want a more minimal script.
