    Insert String Info Into AddStaticText dialog command
    3 Posts 2 Posters 876 Views 1 Watching
    • G Offline
      geese780
      AddStaticText Insert String defined by variable as text name in Python
      Hey guys,
      I'm having a hard time trying to figure out the right order in which I'm trying to use a string obtained by a variable andu use the string infomation as a StaticText. Here's my current working code minus the AddStaticText part which works under the CreateLayout Definition, but it would run that before obtaining the information I would want it to, so I moved it under my Command Definition. Any small insight would be very grateful!
      from c4d import gui, plugins, bitmaps, documents
      class GUI(gui.GeDialog):
          """ Creates the main graphical user interface of the plug-in  """
          BUTTON_ID = 1001
          Checkbox_ID = 1002
          ComboBox_ID = 1003
          AddChild_1 = 1004
          TextEdit = 1005
          def CreateLayout(self):
              self.SetTitle("CAV MVR IMPORTER")  # Set dialog title
              self.AddButton(self.BUTTON_ID, c4d.BFH_LEFT | c4d.BFV_TOP, 100, 25, "Close Dialog")
              self.AddCheckbox(self.Checkbox_ID, c4d.BFH_LEFT | c4d.BFV_TOP, 25, 25, "Checkbox")
              self.AddComboBox(self.ComboBox_ID, 0 | 0, 100, 25, True, True)
              self.AddChild(self.ComboBox_ID, self.AddChild_1, "Drop Down 1")
              #self.AddStaticText(self.TextEdit, 0 | 0, 100, 25, "Test Text", 1)
          def Command(self, id, msg):
              if id == 1001:
                  fn = c4d.storage.LoadDialog()
                  print fn
                  if fn == str:
                      self.AddStaticText(self.TextEdit, 0 | 0, 100, 25, fn, 1)
          # Test dialog
          diag = GUI()
          diag.Open(dlgtype=c4d.DLG_TYPE_MODAL, defaultw=1000, defaulth=400)
      # Execute main()
      Cheers!
      MattG
        Hi @geese780,
        please make use of the Q&A New Functionality and read How to Post Questions, especially about category and tagging system.
        I've setup correctly your post but please do it correctly for the next one.
        Regarding your question, AddStaticText adds a new gadget into the UI, the usual way is to define all the Layout in the CreateLayout method of your GeDialog then defining value after user interaction.
        So in your case, you could use GeDialog.SetString.
        class GUI(c4d.gui.GeDialog):
            BUTTON_ID = 1001
            Checkbox_ID = 1002
            ComboBox_ID = 1003
            AddChild_1 = 1004
            TextEditGroup = 1005
            TextEdit = 1006
                self.AddComboBox(self.ComboBox_ID, c4d.BFH_LEFT | c4d.BFV_TOP, 100, 25, True, True)
                # Create a Group, its usefull because here we adds the StaticText Gadget and to make it appears again
                # LayoutChanged needs to be called, which work only a group.
                if self.GroupBegin(self.TextEditGroup, c4d.BFH_SCALEFIT | c4d.BFV_TOP):
                    self.AddStaticText(self.TextEdit, c4d.BFH_SCALEFIT | c4d.BFV_TOP, 100, 25, "", 1)
                    self.HideElement(self.TextEdit, True)
                self.GroupEnd()
                if id == 1001:
                    # Unhides the Text element
                    self.HideElement(self.TextEdit, False)
                    # Checks if its a str, then display the file path
                    if isinstance(fn, str):
                        self.SetString(self.TextEdit, fn)
                    # If its not a string, the user cancelled
                        self.SetString(self.TextEdit, "User cancelled")
                    # Notify the layout of the group changed, this will invalidate the group and it will be then redraw
                    # This is needed because the UI was hidden, if the Ui is not hidden then there is no need for it
                    self.LayoutChanged(self.TextEditGroup)
            # Test dialog
            diag = GUI()
        # Execute main()
        If there is something you don't understand feel free to ask.
        Maxime
        • G Offline
          geese780
          Thanks Maxime, understood on the rules and regulations, sorry about that.
          I understand the group concept now, read up more on it and I have a better idea on how to approach the goal I'm trying to get to.
          I have another error I'm getting but I'll try to do another post and see if I tag it right!
          Thanks for your time!
          Cheers!
          MattG
