    How to Solo a Layer
    3 Posts 3 Posters 795 Views 2 Watching
    • dskeithD Offline
      dskeith
      I just spent a bit of time debugging a couple issues when trying to Solo a Layer in the Layer Manager, and figured I would post my findings to save someone else some trouble:
      Q: How do you solo a layer?
      layer_root = doc.GetLayerObjectRoot()
      if not layer_root: return
      # Get the first layer in the scene
      layer = layer_root.GetDown()
      if not layer: return
      # Be sure to use the `rawdata` flag so that you get the stored layer state, not the "effective" layer state
      layer_data = layer.GetLayerData(doc, rawdata=True)
      start_solo_state = layer_data["solo"]
      solo_state = True
      layer_data["solo"] = True
      # SetLayerData needs a complete LayerData dict, it doesn't work with something like `{"solo": True}`
      # doing that will force all other layer state flags to be False
      layer.SetLayerData(doc, layer_data)
      # This isn't documented near SetLayerData, but you must call this method or C4D won't know to update the
      # solo state of layers in the scene.
      set_or_clear =
      doc.ChangeNBit(c4d.NBIT_SOLO_LAYER, c4d.NBITCONTROL_SET)
      # Let C4D know something has changed to trigger a redraw
      Documentation Request:
      Please update the docs for SetLayerData to include an example like the above, and make a note that if you plan to SetLayerData you should call GetLayerData with rawdata=True.
      Donovan
      -- Edit 2020/03/20 --
      Actually this isn't working well in all circumstances. If all layers are unsoloed I'm not getting the expected refresh.
      Okay, I think I figured out the issue (but haven't updated the logic above to account for it):
      If you turn off solo on all layers, you need to use doc.ChangeNBit(c4d.NBIT_SOLO_LAYER, c4d.NBITCONTROL_CLEAR), but if even one layer has the solo flag on, you need to use doc.ChangeNBit(c4d.NBIT_SOLO_LAYER, c4d.NBITCONTROL_SET).
      ...I think.
      • P Offline
        PluginStudent
        Did you look into the C++ docs on this issue? Because there you find a Layer Manual.
        • r_giganteR Offline
          r_gigante
          Hi @dskeith thanks for reaching out us.
          As pointed out by @PluginStudent, the NBIT_SOLO_LAYER behavior is explained in the Layer Manuel although it make sense to add a note to the Python API as well.
          With regard to a complete example, I've partially reworked your code to make sure that by executing the script multiple times you can run across all the solo configurations that the scene can handle.
          # Main function
              if not layer_root:
              if not layer:
              soloSet = False
              while layer is not None:
                  # Set `rawdata` to True flag so to get the original layer values without any additional global changes
                  # check the current layer solo state:
                  if layer_data["solo"] == False:
                      # if not "solo" then set to True
                      # update the layer
                      # update the flag
                      soloSet = True
                      break
                  # deactivate if layer solo was True
                  layer_data["solo"] = False
                  # go to next layer
                  layer = layer.GetNext()
              # if one (or more) solo was set the set NBIT_SOLO_LAYER otherwise clear
              if soloSet == True:
              # Add an event
          # Execute main()
