    Exporting Polygonized scene
    pythonr20
    8 Posts 2 Posters 937 Views 1 Watching
    • R Offline
      rui_mac
      I have a script that exports a sequence of OBJ files out of an animated Cinema 4D scene. It works perfectly.
      I would like to be able to do the same, but export as a sequence of C4D files.
      What I need is to export a sequence of frames (the scene has animation, of course), in C4D format, but with everything polygonized.
      I'm using:
                  doc.SetTime(curr_time)
                  # Force the redraw of the document
                  doc.ExecutePasses(None, True, True, True, c4d.BUILDFLAGS_NONE)
                  c4d.EventAdd(c4d.EVENT_FORCEREDRAW)
                  c4d.DrawViews(c4d.DRAWFLAGS_FORCEFULLREDRAW)
                  bufferedNumber = str(frame_num)
                  frame_num=frame_num+1
                  # Export the C4D file
                  file_name = os.path.join(file_path,obj_name+bufferedNumber+".c4d")
                  poly_doc=doc.Polygonize(keepanimation = False)
                  if poly_doc != None: c4d.documents.SaveDocument(poly_doc,file_name,c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST | c4d.SAVEDOCUMENTFLAGS_SAVECACHES,c4d.FORMAT_C4DEXPORT)
      But all the saved files are the same and I wanted each file to export as different frame, already polygonized.
      Is this possible?
        hello,
        This is not really clear to us :
        If your code is working for obj, it should work with c4d.
        We are not sure if the problem is in your code or in your scene.
        I've created that script, it's working with a simple cube animated with keyframes.
        Just a remark about your code, you should use is not None
        if poly_doc is not None:
             ..... dosomething
        from c4d import gui
        import os
        # Main function
            # Retrieves the file name and path
            file_path = doc.GetDocumentPath()
            file_oriname = doc.GetDocumentName()[:-3] #remove .c4d
            for i in xrange(10):
                # Update the document's time
                doc.SetTime(c4d.BaseTime(i, doc.GetFps()))
                # Updates timeline
                c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
                # Sometimes you must execute this twice to be sure cache is built.
                currentFrame = doc.GetTime().GetFrame(doc.GetFps())
                file_name = os.path.join(file_path,file_oriname + str(currentFrame) + ".c4d")
        # Execute main()
        • R Offline
          rui_mac
          I'm trying to export a Dynamics MoGraph animation, with a Voronoi Fracture object.
          If I export as OBJ, it works fine.
          If I export as C4D, all the saved files are the same, and have no animation.
            it seem to have a bug with Polygonize, we are investigating at the moment.
            Some exporter are using this function other aren't. .obj is not that's probably why it's working with obj.
            The Polygonize function is just a "current state to object" for each object in the scene. You can build your own Polygonize function.
            I'll be back when i have more information
              hello,
              Something like this maybe. I needed to create my own "insertLast" function because the GeListHead was not alive in the new document.
              But i don't build my scene with dynamics, could you send us your scene at [email protected] ?
              sorry for the small amount of comment.
              from c4d import gui
              import os
              def GetLast(doc):
                  # retrieves the last element of the document
                  child = doc.GetFirstObject()
                  if child is None:
                      return None
                  while child:
                      if child.GetNext() is None:
                          return child
                      child = child.GetNext()
              def InsertLast(doc, op):
                  # Insert object after the last object in the scene.
                  last = GetLast(doc)
                  if last is None:
                      # that mean this is the first element added in the scene
                      doc.InsertObject(op)
                      op.InsertAfter(last)
              def CSTO(op, keepAnimation = False ):
                  # Current state to object.
                  # the Keep animation will be set in the basecontainer for the command
                  doc = op.GetDocument()
                  # send the modeling command
                  bc = c4d.BaseContainer()
                  bc.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, keepAnimation)
                  res = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
                                              list = [op],
                                              mode = c4d.MODELINGCOMMANDMODE_ALL,
                                              bc = bc,
                                              doc = doc)
                  # Cheks if the command didn't failed
                  if res is False:
                      raise TypeError("return value of CSTO is not valie")
                  # Returns the first object of the list.
                  return res[0]
              def GetNextObject(doc):
                  # get he next object in the scene, only the first level of hierarchy is used.
                  op = doc.GetFirstObject()
                  while op:
                      yield op
                      op=op.GetNext()
              def MyPolygonize(doc, keepAnimation = False):
                  # For each first level element, call a CSTO and store the result in a new document
                  dst = c4d.documents.BaseDocument()
                  if dst is None:
                      raise ValueError("can't create a new document")
                  for op in GetNextObject(doc):
                      res = CSTO(op, keepAnimation)
                      InsertLast(dst, res)
                  return dst
                  dst = None
                      # Updates timeline
                      # Using the flag BUILDFLAGS_INTERNALRENDERER will allow to have the voronoi fracture cache to be calculated
                      doc.ExecutePasses(None, True, True, True, c4d.BUILDFLAGS_INTERNALRENDERER)
                      dst = MyPolygonize(doc, False)
                      if dst is not None:
                          c4d.documents.SaveDocument(dst,file_name,c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST | c4d.SAVEDOCUMENTFLAGS_SAVECACHES,c4d.FORMAT_C4DEXPORT)
              # Execute main()
              • R Offline
                rui_mac
                Thank you very much, Manuel.
                I will send the scene to the e-mail you provided.
                  of course my example doesn't take care of material applied to the object, you need a bit of extra work for that. But shouldn't be too hard.
                  thanks for the scene 🙂
                  • R Offline
                    rui_mac
                    You're welcome, Manuel.
                    Actually, I usually prepare all the textures and mapping to be in UVW mapping, when texturing is required.
                    But, mainly, what I need is exporting geometry that is animated.
