Selecting the text in a GeDialog MultiLineEditText
How does one select all of the text in a GeDialog.AddMultiLineEditText gadget?def CreateLayout(self): self.AddMultiLineEditText(self.multiText, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, initw=0, inith=0, style=c4d.DR_MULTILINE_WORDWRAP) self.SetString(self.multiText,"Placeholder Text.") self.Activate(self.multiText) return TrueI tried getting Message IDs when selecting the text with a right-click > Select All, but all I could trace was
BFM_INTERACTSTARTandBFM_INTERACTEND.I am trying to create a behavior similar to the InputDialog where the text is already selected.
c4d.gui.InputDialog("Dialog Title","Placeholder Text")Thank you!
This can be done by sending directly the correct message:
bc = c4d.BaseContainer(c4d.IDM_SELECTALL) self.SendMessage(10000, bc) # 10000 is the ID of the MultiLineEditText gadgetAnd here a complete example:
import c4d class ExampleDialog(c4d.gui.GeDialog): def CreateLayout(self): self.SetTitle("This is an example Dialog") my_text = """jfsdskdhsdfsd fsd fsd sdf sddsf """ self.AddMultiLineEditText(10000, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, style=c4d.DR_MULTILINE_MONOSPACED | c4d.DR_MULTILINE_HIGHLIGHTLINE | c4d.DR_MULTILINE_READONLY) self.SetString(10000, my_text) # Creates a Ok and Cancel Button self.AddDlgGroup(c4d.DLG_OK | c4d.DLG_CANCEL) return True def Command(self, messageId, bc): if messageId == c4d.DLG_OK: bc = c4d.BaseContainer(c4d.IDM_SELECTALL) self.SendMessage(10000, bc) return True elif messageId == c4d.DLG_CANCEL: self.Close() return True def main(): dlg = ExampleDialog() dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=300, defaulth=200) if __name__ == "__main__": main()Cheers,
Maxime. -
@m_adam You know so much! Thank you for the example code.
You have helped me so much, Maxime, particularly on my current project. I am very grateful!
