    How to Check If you are in a Specific Tab?
    r21python
    3 Posts 2 Posters 333 Views 1 Watching
    • B Offline
      bentraje
      Is there a way to check if you are in a specific tab?
      I have a contextual menu that triggers through RMB.
      It works. The problem is it works on all tabs. It should work on only a specific tab.
      You can see the problem here:
      https://www.dropbox.com/s/nhksy19e74zfxfk/c4d215_check_if_you_are_in_a_specific_tab.mp4?dl=0
      Is there a way around this?
      Thank you.
        A Tab is stored as an Int.
        So you can retrieve the value by GeDialog::GetInt32.
        You have a complete example in What message or Id do I get when the user select a tab in my dialog?
        • B Offline
          bentraje
          @m_adam
          Thanks. Works as expected.
