    No multiple selection in Treeview not working?
    Cinema 4D SDK
    r21 r20 python
    1.8k
    • P
      pim
      I added following statement to the treeview settings, but I can still select multiple objects.
      "TREEVIEW_NO_MULTISELECT bool True if no multiple selection is allowed."
              customgui = c4d.BaseContainer()
              customgui.SetBool(c4d.TREEVIEW_BORDER, c4d.BORDER_THIN_IN)
              customgui.SetBool(c4d.TREEVIEW_HAS_HEADER, True) # True if the tree view may have a header line.
              customgui.SetBool(c4d.TREEVIEW_HIDE_LINES, False) # True if no lines should be drawn.
              customgui.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True) # True if the user can move the columns.
              customgui.SetBool(c4d.TREEVIEW_RESIZE_HEADER, True) # True if the column width can be changed by the user.
              customgui.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True) # True if all lines have the same height.
              customgui.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True) # Alternate background per line.
              customgui.SetBool(c4d.TREEVIEW_CURSORKEYS, True) # True if cursor keys should be processed.
              customgui.SetBool(c4d.TREEVIEW_NOENTERRENAME, False) # Suppresses the rename popup when the user presses enter.
              customgui.SetBool(c4d.TREEVIEW_NO_MULTISELECT, True) #True if no multiple selection is allowed."
              self._treegui = self.AddCustomGui( 1000, c4d.CUSTOMGUI_TREEVIEW, "", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 0, 0, customgui)
              if not self._treegui:
                  print "[ERROR]: Could not create TreeView"
                  return False
      • lasselauchL
        lasselauch
        Hi @pim I came across this recently myself then I found out in the documentation it states:
        TreeViewFunctions.GetDragType() returns: The object drag type, or c4d.NOTOK to disable drag-and-drop
        So, try setting the GetDragType to c4d.NOTOK:
            def GetDragType(self, root, userdata, obj):
                return c4d.NOTOK
        Hope it helps.
        Lasse
        • P
          pim
          @lasselauch said in No multiple selection in Treeview not working?:
              return c4d.NOTOK
          Sorry, that did not solve the issue.
          Multiple selection is still possible!
          Also you say "c4d.NOTOK to disable drag-and-drop", but I want to disable multiple selections in the treeview.
          -Pim
          • lasselauchL
            lasselauch
            It was either this or disabling the DragStart function that did the trick for me can't remember exactly, sorry.
            However, it seems a bit odd that you can set the Flag TREEVIEW_NO_MULTISELECT to True and it still let's you drag Objects.
            • P
              pim
              Isn' there a difference between selecting and drag-and-drop an object?
              • M
                Hi Pim I'm not able to reproduce
                import weakref
                # Be sure to use a unique ID obtained from [URL-REMOVED]
                PLUGIN_ID = 1000010 # TEST ID ONLY
                # TreeView Column IDs.
                ID_CHECKBOX = 1
                ID_NAME = 2
                ID_OTHER = 3
                def TextureObjectIterator(lst):
                    for parentTex in lst:
                        yield parentTex
                        for childTex in TextureObjectIterator(parentTex.GetChildren()):
                            yield childTex
                class TextureObject(object):
                    Class which represent a texture, aka an Item in our list
                    texturePath = "TexPath"
                    otherData = "OtherData"
                    _selected = False
                    _open = True
                    def __init__(self, texturePath):
                        self.texturePath = texturePath
                        self.otherData += texturePath
                        self.children = []
                        self._parent = None
                    @property
                    def IsSelected(self):
                        return self._selected
                    def Select(self):
                        self._selected = True
                    def Deselect(self):
                        self._selected = False
                    @property
                    def IsOpened(self):
                        return self._open
                    def Open(self):
                        self._open = True
                    def Close(self):
                        self._open = False
                    def AddChild(self, obj):
                        obj._parent = weakref.ref(self)
                        self.children.append(obj)
                    def GetChildren(self):
                        return self.children
                    def GetParent(self):
                        if self._parent:
                            return self._parent()
                        return None
                    def __repr__(self):
                        return str(self)
                    def __str__(self):
                        return self.texturePath
                class ListView(c4d.gui.TreeViewFunctions):
                    def __init__(self):
                        self.listOfTexture = list() # Store all objects we need to display in this list
                        # Add some defaults values
                        t1 = TextureObject("T1")
                        t2 = TextureObject("T2")
                        t3 = TextureObject("T3")
                        t4 = TextureObject("T4")
                        self.listOfTexture.extend([t1, t2, t3, t4])
                    def IsResizeColAllowed(self, root, userdata, lColID):
                    def IsTristate(self, root, userdata):
                        return False
                    def GetColumnWidth(self, root, userdata, obj, col, area):
                        return 80  # All have the same initial width
                    def IsMoveColAllowed(self, root, userdata, lColID):
                        # The user is allowed to move all columns.
                        # TREEVIEW_MOVE_COLUMN must be set in the container of AddCustomGui.
                    def GetFirst(self, root, userdata):
                        Return the first element in the hierarchy, or None if there is no element.
                        rValue = None if not self.listOfTexture else self.listOfTexture[0]
                        return rValue
                    def GetDown(self, root, userdata, obj):
                        Return a child of a node, since we only want a list, we return None everytime
                        children = obj.GetChildren()
                        if children:
                            return children[0]
                        return None
                    def GetNext(self, root, userdata, obj):
                        Returns the next Object to display after arg:'obj'
                        rValue = None
                        # If does have a child it means it's a child.
                        objParent = obj.GetParent()
                        listToSearch = objParent.GetChildren() if objParent is not None else self.listOfTexture
                        currentObjIndex = listToSearch.index(obj)
                        nextIndex = currentObjIndex + 1
                        if nextIndex < len(listToSearch):
                            rValue = listToSearch[nextIndex]
                        return rValue
                    def GetPred(self, root, userdata, obj):
                        Returns the previous Object to display before arg:'obj'
                        rValue = None
                        predIndex = currentObjIndex - 1
                        if 0 <= predIndex < len(listToSearch):
                            rValue = listToSearch[predIndex]
                        return rValue
                    def GetId(self, root, userdata, obj):
                        Return a unique ID for the element in the TreeView.
                        return hash(obj)
                    def Select(self, root, userdata, obj, mode):
                        Called when the user selects an element.
                        if mode == c4d.SELECTION_NEW:
                            for tex in self.listOfTexture:
                                tex.Deselect()
                            obj.Select()
                        elif mode == c4d.SELECTION_ADD:
                            obj.Select()
                        elif mode == c4d.SELECTION_SUB:
                            obj.Deselect()
                    def IsSelected(self, root, userdata, obj):
                        Returns: True if *obj* is selected, False if not.
                        return obj.IsSelected
                    def SetCheck(self, root, userdata, obj, column, checked, msg):
                        Called when the user clicks on a checkbox for an object in a
                        `c4d.LV_CHECKBOX` column.
                        if checked:
                            obj.Select()
                            obj.Deselect()
                    def IsChecked(self, root, userdata, obj, column):
                        Returns: (int): Status of the checkbox in the specified *column* for *obj*.
                        if obj.IsSelected:
                            return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                            return c4d.LV_CHECKBOX_ENABLED
                    def IsOpened(self, root, userdata, obj):
                        Returns: (bool): Status If it's opened = True (folded) or closed = False.
                        # If there is some children
                        return obj.IsOpened
                    def Open(self, root, userdata, obj, onoff):
                        Called when the user clicks on a folding state of an object to display/hide its children
                        if onoff:
                            obj.Open()
                            obj.Close()
                    def GetName(self, root, userdata, obj):
                        Returns the name to display for arg:'obj', only called for column of type LV_TREE
                        return str(obj) # Or obj.texturePath
                    def DrawCell(self, root, userdata, obj, col, drawinfo, bgColor):
                        Draw into a Cell, only called for column of type LV_USER
                        if col == ID_OTHER:
                            name = obj.otherData
                            geUserArea = drawinfo["frame"]
                            w = geUserArea.DrawGetTextWidth(name)
                            h = geUserArea.DrawGetFontHeight()
                            xpos = drawinfo["xpos"]
                            ypos = drawinfo["ypos"] + drawinfo["height"]
                            drawinfo["frame"].DrawText(name, xpos, ypos - h * 1.1)
                    def DoubleClick(self, root, userdata, obj, col, mouseinfo):
                        Called when the user double-clicks on an entry in the TreeView.
                        Returns:
                          (bool): True if the double-click was handled, False if the
                            default action should kick in. The default action will invoke
                            the rename procedure for the object, causing `SetName()` to be
                            called.
                        c4d.gui.MessageDialog("You clicked on " + str(obj))
                    def DeletePressed(self, root, userdata):
                        "Called when a delete event is received."
                        for tex in reversed(list(TextureObjectIterator(self.listOfTexture))):
                            if tex.IsSelected:
                                listToRemove = objParent.GetChildren() if objParent is not None else self.listOfTexture
                                listToRemove.remove(tex)
                class TestDialog(c4d.gui.GeDialog):
                    _treegui = None # Our CustomGui TreeView
                    _listView = ListView() # Our Instance of c4d.gui.TreeViewFunctions
                    def CreateLayout(self):
                        # Create the TreeView GUI.
                        self._treegui = self.AddCustomGui( 1000, c4d.CUSTOMGUI_TREEVIEW, "", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 300, 300, customgui)
                            return False
                        self.AddButton(1001, c4d.BFH_CENTER, name="Add")
                        self.AddButton(1002, c4d.BFH_CENTER, name="Add Child to selected")
                    def InitValues(self):
                        # Initialize the column layout for the TreeView.
                        layout = c4d.BaseContainer()
                        layout.SetLong(ID_CHECKBOX, c4d.LV_CHECKBOX)
                        layout.SetLong(ID_NAME, c4d.LV_TREE)
                        layout.SetLong(ID_OTHER, c4d.LV_USER)
                        self._treegui.SetLayout(3, layout)
                        # Set the header titles.
                        self._treegui.SetHeaderText(ID_CHECKBOX, "Check")
                        self._treegui.SetHeaderText(ID_NAME, "Name")
                        self._treegui.SetHeaderText(ID_OTHER, "Other")
                        self._treegui.Refresh()
                        # Set TreeViewFunctions instance used by our CUSTOMGUI_TREEVIEW
                        self._treegui.SetRoot(self._treegui, self._listView, None)
                    def Command(self, id, msg):
                        # Click on button
                        if id == 1001:
                            # Add data to our DataStructure (ListView)
                            newID = len(self._listView.listOfTexture) + 1
                            tex = TextureObject("T{}".format(newID))
                            self._listView.listOfTexture.append(tex)
                            # Refresh the TreeView
                        elif id == 1002:
                            for parentTex in TextureObjectIterator(self._listView.listOfTexture):
                                if not parentTex.IsSelected:
                                    continue
                                newID = len(parentTex.GetChildren()) + 1
                                tex = TextureObject("T{0}.{1}".format(str(parentTex), newID))
                                parentTex.AddChild(tex)
                    global dialog
                    dialog = TestDialog()
                    dialog.Open(c4d.DLG_TYPE_ASYNC, defaulth=600, defaultw=600)
                Can you share your code? and on which version are you? Which OS?
                • P
                  pim
                  OK, I can reproduce it in your code.
                  It goes wrong when you add children (using the button on the bottom of the dialog).
                  You can select multiple children.
                  Parent objects, you can indeed only select one.
                  I guess AddChild() should be changed?
                  • P
                    pim
                    I also noticed that deselecting a child does not work.
                    def Select(self, root, userdata, obj, mode) does not deselect children when the mode is c4d.SELECTION_NEW.
                    However, I cannot find what is wrong.
                    • M
                      mp5gosu
                      I would guess that TreeView items are arbitrary nodes and only top level nodes are managed (and even then - only if they are already of the right type like GeListNode)
                      So you have to take care about any node items, because they simply do not belong directly to the treeview and thus cannot be managed.
                      If you write custom list classes, you have to do the selection management manually anyway. 🙂
                      Cheers.
                      • P
                        pim
                        I think you are right.
                        Doing it 'manually' works fine.
                        # deselect all
                        for tex in TextureObjectIterator(self._listView.listOfTexture):
                              tex.Deselect()
                        But let's see what Maxon replies.
                        • M
                          Hi @pim, TREEVIEW_NO_MULTISELECT only change SELECTION_ADD to SELECTION_NEW when the Select method is called.
                          So you have to support parent properly (which is not the case in my previous scrip), but you can adapt the Select method like so (Note that since our checked method, also select the object the TREEVIEW_NO_MULTISELECT don't prevent at all to have multiple stuff selected).
                                      for tex in TextureObjectIterator(self.listOfTexture):
                                          tex.Deselect()
                                      obj.Select()
                                      obj.Select()
                                      obj.Deselect()
                          • P
                            pim
                            Thanks, that solved the issue.
                            -Pim
