    Menu items without RegisterCommandPlugin?
    11 Posts 3 Posters 2.2k Views 1 Watching
    • jcooperJ Offline
      jcooper
      Is it possible to set up custom menus with menu items that execute python code without setting up a "plugin" and registering it with RegisterCommandPlugin?
      We have a facility standard menu framework that creates a custom menu populated with items that correspond to python scripts found on disk under an artist's current working project. One of the menu items is a "Refresh" command that re-builds the menu, used for when scripts are added/deleted while the user is in C4D (and we don't want to force them to exit their session and restart C4D just to have this menu re-built).
      This mechanism works in all our other DCCs, such as Maya, Nuke, etc., but the need to register every single menu item as a plugin that can only be registered with C4D at startup makes the Refresh mechanism useless under C4D.
      Suggestions?
      JOHN COOPER I TECHNICAL DIRECTOR
      PSYOP LA
      • lasselauchL Offline
        lasselauch
        Hi John,
        you should be able to enhance the menu using a simple python-script (i.e. refresh command), but I've haven't tried it myself. Here's a small example on enhancing the menu:
        Enhance Menu Example
        From there you can list your local python-scripts, however you need a simple function to run() those "external" scripts.
        I'm currently using this function for one of my plugins which more or less does the same:
            def execute_script(self, filename):
                fl = open(filename, 'rb')
                code = compile(fl.read(), filename, 'exec')
                scope = {
                '__file__': filename,
                '__name__': '__main__',
                'doc': doc,
                exec code in scope
        There are some downsides to using this function but it might get you started...
        Lasse
          Hi @jcooper, as @lasselauch pointed you, usually to build menu its recommended to create a plugin that will react to the C4DPL_BUILDMENU message.
          However, if you want a one time action this is possible.
          Now regarding your question to have a custom folder, this is not properly supported by Cinema 4D so either you will have to use @lasselauch workaround but then I don't really see how to make dynamic CommandData for each entry since in Python there is no way to dynamically creates CommandData within the script manager since plugins can only be registered in a pyp file.
          Or you can put them in the Cinema 4D script folder located in:
          • Windows: %APPDATA%/MAXON/{cinemaversion}/library/scripts.
          • MacOS: ~/Library/Preferences/MAXON/{cinemaversion}/library/scripts.
            or defined by the enviroment variable C4D_SCRIPTS_DIR
          The benefice of the last decision is that Cinema 4D will load these scripts and create a CommandData for each of them dynamically. This way you can retrieve this commanddata and build the menu. Note that to retrieve the associated CommandData id, I search by plugin name, so be sure to have a unique name for your script.
          Here an example, that will build a menu ( I have 2 scripts, testScript and createMenu😞
          def GetScriptIdByName(name):
              pluginList = c4d.plugins.FilterPluginList(c4d.PLUGINTYPE_COMMAND, True)
              for plugin in pluginList:
                  if plugin.GetName() == name:
                      return plugin.GetID()
              return None
          def GetMenuContainer(name):
              mainMenu = c4d.gui.GetMenuResource("M_EDITOR")
              customMenu = c4d.BaseContainer()
              for bcMenuId, bcMenu in mainMenu:
                  if bcMenu[c4d.MENURESOURCE_SUBTITLE] == name:
                      customMenu = mainMenu.GetContainerInstance(bcMenuId)
                      break
              if customMenu is not None:
                  customMenu.FlushAll()
              customMenu.InsData(c4d.MENURESOURCE_SUBTITLE, name)
              return customMenu
          def AddsMenuToC4DMenu(menu):
                  if bcMenu[c4d.MENURESOURCE_SUBTITLE] == menu[c4d.MENURESOURCE_SUBTITLE]:
              mainMenu.InsData(c4d.MENURESOURCE_STRING, menu)
          def AddEntry(menuContainer, scriptName):
              scriptId = GetScriptIdByName(scriptName)
              if scriptId is None:
              menuContainer.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_{0}".format(scriptId))
          # Main function
              menuName = "Custom Python menu"
              menuContainer = GetMenuContainer(menuName)
              AddEntry(menuContainer, "testScript")
              AddEntry(menuContainer, "createMenu")
              AddsMenuToC4DMenu(menuContainer)
              c4d.gui.UpdateMenus()
          # Execute main()
            lasselauch
            Nice, thanks for the example @m_adam!
            I always thought you have to restart c4d to reload all the scripts located in the scripts folder..!?
              m_adam @lasselauch
              @lasselauch Correct but the idea is to have all the scripts already loaded.
                lasselauch
                Well, one request was to "Refresh" the menu when scripts are added/deleted while the user is in C4D, this is sadly a limitation and not possible with your solution... am I right?!
                  @lasselauch correct.
                  • jcooperJ Offline
                    jcooper
                    As @lasselauch points out, the issue is the functionality of the "Refresh" command.
                    I've added C4D support for our menu generation framework and it creates a hierarchical menu matching the python scripts it finds on disk just fine. Execution of those scripts works too.
                    The only issue is the inability of the Refresh menu item to rebuild the menu when it encounters a new script that didn't exist when C4D was launched.
                    I guess my only recourse is to pop up a MessageDialog telling the user that the Refresh command simply doesn't work in Cinema 4D.
                    PSYOP LA
                      lasselauch
                      Hm, but it would be possible to Flush the whole Menu, rebuild it and reinitialize the updated Menu via c4d.gui.UpdateMenus(), wouldn't it!?
                      • jcooperJ Offline
                        jcooper
                        My menugen code is able to rebuild the menu.
                        However, when it tries to use RegisterCommandPlugin() for the new python scripts it finds on disk, C4D issues an error indicating it can't find a .pyp file. Apparently this is because RegisterCommandPlugin() can't be used at any time except at application launch. And without the ability to RegisterCommandPlugin() for the new scripts, I can't add them to the newly built menu as menu items.
                        PSYOP LA
                          Hi, I'm sorry for the delay, but I can only confirm what you said.
                          In C++ it's possible to call RegisterCommandPlugin but not in Python at runtime.
                          So I guess the best approach is to have as you suggested a menu entry (a pre-registered c4d script or CommandData) that will then create a PopuDialog with a list of all scripts, and then it's up to you to execute them with the code @lasselauch provided.
                          So here an example of how to implement it.
                          import os
                              # Gets all python script of a folder
                              searchPath = r"%appdata%\Roaming\Maxon\Maxon Cinema 4D R21_115_XXXXXX\library\scripts"
                              pythonFiles = [os.path.join(folder, f) for f in os.listdir(folder) if os.path.isfile(os.path.join(folder, f)) and f.endswith(".py")]
                              # Build the menu for all the entries
                              menu = c4d.BaseContainer()
                              for pythonFileId, pythonFile in enumerate(pythonFiles):
                                  menuId = c4d.FIRST_POPUP_ID + pythonFileId
                                  filename = os.path.basename(pythonFile)
                                  menu.InsData(menuId, filename)
                              # Example to also list regular command.
                              # Uses POPUP_EXECUTECOMMANDS in ShowPopupDialog flag so if its a command its executed directly
                              menu.InsData(c4d.Ocube, "CMD")
                              # Display the PopupDialog
                              result = c4d.gui.ShowPopupDialog(cd=None, bc=menu, x=c4d.MOUSEPOS, y=c4d.MOUSEPOS, flags=c4d.POPUP_EXECUTECOMMANDS | c4d.POPUP_BELOW | c4d.POPUP_CENTERHORIZ)
                              # If result is bigger than FIRST_POPUP_ID it means user selected something
                              if result >= c4d.FIRST_POPUP_ID:
                                  # Retrieves the selected python file
                                  scriptId = result - c4d.FIRST_POPUP_ID
                                  pythonFile = pythonFiles[scriptId]
                                  # Execute it and copy the global to it ( so doc, op are accessible as well)
                                  fl = open(pythonFile, 'rb')
                                  code = compile(fl.read(), pythonFile, 'exec')
                                  exec(code, globals())
                          # Execute main()
