    Integrating a CallCommand() with Built-In Save Dialog?
    r21python
    3 Posts 2 Posters 383 Views 1 Watching
    • B Offline
      bentraje
      I'm trying to create a script that
      1. Exports All Skin Weights in the Scene to an External File
      2. Name Each file with an Object Name
      I want to piggy back on C4D's Save Weights (under the Weight Manager) with the c4d.CallCommand(1028186)
      The problem is I don't know how to perform the naming of each file.
      When I execute c4d.CallCommand(1028186), I have no access to the Save Dialog.
      Is there a way around this? Or should I just create my own weight saver (ouch)?
      Thank you for looking at my problem.
        it's not possible to bypass that dialogbox or set a filename.
        Using CallCommand is like a user pressing a button in the UI, so if you have a DialogBox, you are blocked and you must use something else.
        It is possible to retrieve all the weight for all joints.
        some doc that could help you :
        • the weight manager
        • the weight manager c++ manual
        • the Weight Tag functions
        on the tag function you got the GetWeightMap that is interesting.
        You can export that to a binary format of you own or an xml, it's up to you.
        Manuel.
        • B Offline
          bentraje
          @m_magalhaes
          Thanks for the confirmation.
