    Xpresso Python Node . "Code" field
    8 Posts 3 Posters 1.4k Views 1 Watching
    • esanE Offline
      esan
      R20
      I need to add an "Object" port to an object node, but I guess since I have R20 with that particular python bug preventing it, I need to find a workaround. All I need to do is get the currently instanced objects name, fed back into the display name (and appending with another string in here). Ive seen that "UserData" workaround to get a makeshift Object port but that feels heavy handed for my case. Thought a python node with simple script can replace my Object node and Name port like so
      And this works, but cant seem to figure out how to "set" this Python Code in this Node via my Python Script. Have made this snippet of code a function and was trying everything from OperatorSetData, and even the InsertObjects through In/Exclude method I was just shown for my Link List question. But nothing ive done yet seems to populate the field. Final Stretch! Thanks for all the help thus far, this script has already been an amazing learning experience.
          global Output2
          global Input3
          Output2 = c4d.BaseList2D.GetName(Input3)
      • CairynC Offline
        Cairyn @esan
        @esan Your Python node and code do not match up. You have renamed the ports to Link and String but in your code the globals that are supposed to connect to the ports are named Output2 and Input3. This must be consistent.
        You can write the call to GetName easier as well by invoking it on the object (the input port).
            global TheLink, ObjName # ports
            ObjName = TheLink.GetName()
        • esanE Offline
          esan
          @Cairyn
          Sorry, i have a lot of permutations of this and the code snippet isn't from that exact node pictured, just grabbed examples at random since the point of the question was asking how to populate the Python Node Code field with my Python Script. Once that works then yes ill make all the proper ports/names to accommodate, that part i have figured out and got working, just inserting code into the field is what im missing. Thanks
            Hi you can define the python code as you will do for any BaseList2D parameter with SetParameter since GvNode is a child of BaseList2D.
            So you can drag and drop parameter as explained in the Python Console Manual
            esanE 2 Replies Last reply Reply Quote 1
            • esanE Offline
              esan @m_adam
              @m_adam
              ahh, palm securely in face. Ya I had the GV_PYTHON_CODE but since I had spent so much time wrapping my head around this OperatorSetData in the node world prior I overcomplicated it from the start. Hadnt come across that console manual either, thanks a lot!
              • esanE Offline
                esan @m_adam
                @m_adam
                So final question. When i execute node[2][c4d.GV_PYTHON_CODE] = 'test string', all is well. When i try to exectute this as a function, i get errors. This setup gives me error " setitem expected str, not None"
                i wanted to do a multi-line string incapsulation but the triple quotes seem to be reserved for title/headers in this environment. How would i go about conveying that this function is a Str if making it a bucket of strings doesnt do it?
                def pythonNodeCode():
                    'import c4d'
                    'def main():'
                    '    global Output2'
                    '    global Input3'
                    '    Output2 = c4d.BaseList2D.GetName(Input3)'
                    #skip a lot of other code
                    node[2][c4d.GV_PYTHON_CODE] = pythonNodeCode()
                (i tried node[2][c4d.GV_PYTHON_CODE] = str(pythonNodeCode()) too just to make sure the obvious wasnt sitting in my face)
                edit: I achieved the intent with this, but still interested in the non-atrocious way to write it lol
                 node[2][c4d.GV_PYTHON_CODE] = 'import c4d \n\ndef main():\n\n    global Output2\n    global Input3\n\n    Output2 = c4d.BaseList2D.GetName(Input3)'
                • CairynC Offline
                  Cairyn @esan
                  @esan Your first version does not assign the string(s) to anything - a return is missing. What pythonNodeCode() is actually doing is to define a number of strings that are then discarded, and to return None as this is the default.
                  You can write it line by line if you add the \n manually to each line, and force Python to concatenate the strings by using line continuation \
                      return \
                          'import c4d\n'\
                          'def main():\n'\
                          '    global Output2\n'\
                          '    global Input3\n'\
                          '    Output2 = c4d.BaseList2D.GetName(Input3)\n'\
                  I don't quite see why triple quotation should not work, maybe same issue?
                      return '''
                      global Output2
                      global Input3
                  • esanE Offline
                    esan
                    @Cairyn
                    Ah youre right, the Return was the cause of the errors, not the triple quotes. Got it all working now! (after taking a few tries to get the "indents" with the strings right)
                    Thanks a ton!
