    Unexpected Margin/Padding on AddCustomGui
    r21python
    12 Posts 2 Posters 1.4k Views 1 Watching
    • B Offline
      bentraje
      @m_adam
      Thanks for the response.
      I added a line with
      bcBitmapButton[c4d.BITMAPBUTTON_FORCE_SIZE] = 100.00
      and revised a line to
      bitmapButton = self.AddCustomGui(buttonId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFV_CENTER | c4d.BFV_CENTER , w, h,
      However, it still gives an unwanted margin/padding but this time at the bottom.
      You can see the problem here:
      https://www.dropbox.com/s/i6eb8ccszzc35ov/c4d191_unexpected_margin_on_custom_gui_button_02.jpg?dl=0
        Hi @bentraje
        Could you try to use
                w = c4d.gui.SizePix(100)
                h = c4d.gui.SizePix(100)
        For more information see GUI Layout Issues.
        If not could you try to zip bmp + a complete working script?
        Thanks in advance,
        • B Offline
          bentraje
          Almost close now. is there a way to totally remove the border space within the custom gui buttons?
          You can check it here:
          https://www.dropbox.com/s/vs31t2flu51gnej/c4d191_unexpected_margin_on_custom_gui_button_03.jpg?dl=0
          I tried the self.GroupSpace(0, 0) but it has no effect.
          I also tried self.GroupBorderSpace(0, 0, 0, 0) but the whole button disappeared.
          Are there any other settings for spaces?
            Here is working correctly, please share your code.
                def CreateLayout(self):
                    self.GroupBegin(10002, c4d.BFH_SCALE| c4d.BFV_SCALE,  initw=50, inith=50)
                    bcBitmapButton = c4d.BaseContainer()
                    bcBitmapButton[c4d.BITMAPBUTTON_BUTTON] = True
                    bcBitmapButton[c4d.BITMAPBUTTON_ICONID1] = c4d.Ocube
                    bcBitmapButton[c4d.BITMAPBUTTON_BORDER] = c4d.BORDER_IN
                    buttonId = 2000
                    self.GroupBegin(id=9001, flags=c4d.BFH_SCALEFIT, groupflags = c4d.BFV_GRIDGROUP_EQUALCOLS | c4d.BFV_GRIDGROUP_EQUALROWS, cols=4, rows=4,initw=0, inith=0)
                    for imageId in xrange(10):
                        bitmapButton = self.AddCustomGui(imageId, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton)
                    self.GroupEnd()
                    self.GroupEnd()
            • B Offline
              bentraje
              @m_adam
              There's actually still space between buttons on your code.
              Anyhow here is my working code for your reference. It's in archive file since it includes the images
              https://www.dropbox.com/s/leb10klpvm4o8ps/c4d191_unexpected_margin_on_custom_gui_button.rar?dl=0
                Hi @bentraje
                thanks for the archive.
                Here my code in R21.115
                In your code you call self.GroupSpace(0, 0) before the GroupBegin it has to be called just after the creation.
                Which give me the next result
                • B Offline
                  bentraje
                  Oh I see. Thanks for pointing that out.
                  Thanks!
                  • B Offline
                    bentraje
                    @m_adam
                    Sorry for reviving the thread but I just hit a snag on using the same code but for colored buttons. It doesn't respect the settings and gives an unnecessary margin even though I used the c4d.gui.SizePix() code.
                    https://www.dropbox.com/s/17yqc1i0puoau77/c4d191_unexpected_margin_on_custom_gui_button_04.jpg?dl=0
                    You can see the working code here:
                    from c4d import bitmaps, documents, gui, plugins, threading, utils
                    class ColorButton(object):
                        def __init__(self):
                            self.width = None
                            self.height = None
                            self.color = None
                            self.btn_id = 3000
                        def create(self, dlg, w, h, color, btn_id):
                            self.width = c4d.gui.SizePix(w)
                            self.height = c4d.gui.SizePix(h)
                            self.color = color
                            bmp_color = c4d.bitmaps.BaseBitmap()
                            bmp_color.Init(w, h)
                            for y in xrange(w):
                                for x in xrange(h):
                                    bmp_color.SetPixel(x, y, color[0], color[1], color[2])
                            bmp_btn = dlg.AddCustomGui(btn_id, c4d.CUSTOMGUI_BITMAPBUTTON, "",c4d.BFH_FIT|c4d.BFV_TOP, w, h, bcBitmapButton)
                            bmp_btn.SetImage(bmp_color, True)
                    class MyDialog(c4d.gui.GeDialog):
                            buttonId = 2000
                            # Red Button Through Class
                            red_button = ColorButton()
                            red_button.create(self, w=100,h=100,color=(255,0,0), btn_id=6000)
                            self.GroupEnd()
                            self.GroupEnd()
                        dlg = MyDialog()
                        dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC)
                      m_adam @bentraje
                      @bentraje said in Unexpected Margin/Padding on AddCustomGui:
                      You don't use c4d.gui.SizePix() in your code and that's why it fails.
                      • B Offline
                        bentraje
                        You are right.
                        self.color = color
                        wasn't actually used.
                        Will close this thread now and crawl to my little cave of shame. lol
