    Create BaseBitmap() from Text?
    r21python
    5 Posts 2 Posters 540 Views 1 Watching
    • B Offline
      bentraje
      Is it possible to create bitmap from text?
      Currently, I use separate thumbnail/image files to be use as bitmap but they are relatively simple
      that perhaps I can do them at run time in C4D.
      You can see what I am after in this image:
      https://www.dropbox.com/s/a2saczuy5ah5jnf/c4d208_create_text_as_bitmap.jpg?dl=0
      The use case for this is a toggle button for HIDE/UNHIDE visibility control. The Green means hide and the Red means unhide. I already have the toggle functionality implemented, its only the BaseBitmap() from Text portion.
      Thank you
        Hi @bentraje
        this can be achieved with the c4d.bitmaps.GeClipMap and GeClipMap.TextAt.
        There is an example of GeClipMap in geclipmap_fill_color_bitmap_r18.py.
        Or you can Create a GeUserArea that will display your BaseBitmap GeUserArea.DrawBitmap and then call GeUserArea.DrawText
        The use of GeUserArea is preferred since it's faster than using a GeClipMap. But you can't retrieve a BaseBitmap from your GeUserArea drawing result, so it's up to you do decide which one fits the best for your use case.
        • B Offline
          bentraje
          @m_adam
          Thanks for the response. I was able to draw a text with a colored background.
          Just hit a snag on this portion.
          GeClipMap.SetFont(font_description, font_size)
          I'm assuming the font description is the font name and font type.
          How do I set it to Segoe UI with Bold style?
            This is a bit tricky since Font are not so well organized.
            So the best way I found is
            def GetSegoeUiBoldFont():
                bcFonts = c4d.bitmaps.GeClipMap.EnumerateFonts(c4d.GE_CM_FONTSORT_HIERARCHICAL)
                for familyId, familyBc  in bcFonts:
                    for fontDescriptionId, fontDescription in familyBc:
                        if fontDescription[508] == "SegoeUI-Bold":
                            return fontDescription
            And if you want another font, simply print the content of fontDescription and see which one may fit the best for you.
            • B Offline
              bentraje
              @m_adam
              Thanks for the response. For some reason, the return value is not accepted by the SetFont. It does not error out. It just uses the default font.
              In addition, how were you able to determine that the [508] is for the font name? I can't seem to see such reference in the documentation.
              You can check the working code here:
              from c4d import gui
                              print fontDescription
                  w = 50
                  h = 50
                  image_with_text = c4d.bitmaps.GeClipMap()
                  image_with_text.Init(w=w,h=h,bits=32)
                  image_with_text.BeginDraw()
                  image_with_text.SetColor(125,255,255)
                  image_with_text.FillRect(x1=0,y1=0,x2=50,y2=50)
                  image_with_text.SetColor(0,0,0)
                  font_bc = GetSegoeUiBoldFont()
                  print font_bc
                  font_size = 15
                  image_with_text.SetFont(font_bc,font_size)
                  image_with_text.TextAt(x=10,y=15,txt='head')
                  image_with_text.EndDraw()
                  bmp = image_with_text.GetBitmap()
                  c4d.bitmaps.ShowBitmap(bmp)
              # Execute main()
