Right Click Contextual Menu on a Button?
Is there a way I can have flyout/contextual menu when I right click button?
Currently, the default menu pops up when I do so.
You can see the illustration of the problem here:
https://www.dropbox.com/s/49rvo8w4qh77ozj/c4d202_rmb_contextual_menu_on_button.mp4?dl=0Is there a direct way of doing this? That is a parameter of the
AddButtonelement that allows such feature. There seems to be none in the documentation, but still want to confirm.There is also a working code of RMB Contextual Menu on this thread. The problem is the RMB Contextual Menu is the same in all areas of the GeDialog.
I was thinking of just isolating the function in the area ofbutton(i.e. indirect way).
If so, how do I determine the X,Y area ofbuttonrelative to the dialog? Although of course, I'd prefer the direct way. heheheThanks for looking at my problem
Hi @bentraje,
GeDialog.GetItemDim Can be used to retrieve x/y and size/height of a gadget. Of course, the dialog needs to be open, otherwise, you will get weird results.
So if you modify the code provided in Disable default Right-Click Menu of IsPositionInGuiArea with the next one is working as expected.
def IsPositionOnGadget(self, gadgetId, x, y): # Be sure that the windows is opened, # in our case since we call it in BFM_INTERACTSTART it's ok buttonData = self.GetItemDim(gadgetId) if not buttonData["x"] < x < buttonData["x"] + buttonData["w"]: return False if not buttonData["y"] < y < buttonData["y"] + buttonData["h"]: return False return TrueCheers,
Maxime. -
Works as expected! Thanks again for the sample code, makes everything clear.
