    Simple way to save images?
    r21python
    5 Posts 2 Posters 770 Views 1 Watching
    • B Offline
      bentraje
      Is there a simple way to save images?
      Here's what I have so far
      w = 50
      h = 50
      image = c4d.bitmaps.BaseBitmap()
      image.Init(w, h) # creating a black image for illustration
      image.Save(
              name="See Appendix A",
              format=c4d.FILTER_JPG,
              data="See Appendix B",
              savebits=SAVEBIT_NONE)
      Appendix A:
      I was thinking to be just a simple C:\Users\Luke\Desktop\black_image.jpg
      but it requires a Union[str, c4d.storage.MemoryFileStruct. There is an existing sample script for it in GitHub. It says it "saves" an image but it doesn't use the BaseBitmap.Save code so I'm lost how to use it.
      Appendix B:
      I'm not sure what data is this. Isn't the BaseBitmap the data to be saved? In the example above, the image variable. Correct me if I'm wrong
      Is there a way around this? Thank you for looking at my problem
      • B Offline
        bentraje
        Stupid me. The simple way actually works. I don't have to use the c4d.storage.MemoryFileStruct and also use \\ instead of a single \ for the path.
        Here is the working code:
            w = 50
            h = 50
            image.Init(w, h)
            c4d.bitmaps.ShowBitmap(image)
            filename = 'C:\\Users\\Luke\\Desktop\\black_image.jpg'
            image.Save(filename, c4d.FILTER_JPG, c4d.BaseContainer(), c4d.SAVEBIT_NONE)
        Here is the thread where I got the sample code. For some reason, reading the documentation sometimes give me more problem than solution.
        Anyhow, no further action needed.
          Hi, @bentraje I'm happy you solved your issue.
          @bentraje said in Simple way to save images?:
          This is more related to python in general so if you write \n it will create a line break. So either you have to escape the backslash to avoid python to think you wanted a line break either you can tell to use this string as it is using raw string by writing an "r" before the string declaration.
          rawString = r"C:\Users\Luke\Desktop\black_image.jpg"
          I'm not sure what's it's unclear in the description of BaseBitmap.Save, maybe the description of name should be A path to the destination file?
          If you have any feedback please let me know so I can adapt it as soon as possible 😉
          • B Offline
            bentraje
            Oh so that's the reason for the r"" code
            On the documentation, I'm just confused on the parameter Union[str, c4d.storage.MemoryFileStruct].
            I was not sure how to "union" it.
            I guess its either or? I mean you can either use str or use the c4d.storage.MemoryFileStruct or both.
            But again, I have no background in programming. Maybe this is just a common semantics that I missed out on.
              Union
              This means it can be either a str or either a c4d.storage.MemoryFileStruct. (Both don't really make sense).
