    GUI Layout Issues
    pythonsdk
    4 Posts 2 Posters 695 Views 2 Watching
    • ? Offline
      A Former User
      I'm trying to lay out my GUI and I'm having some difficulty. Here's what I have so far:
      Here's what I'd like to make:
      ISSUES:
      1. I'd like to center text #1 "TITLE" in its parent group. Thought I am using the flags c4d.BFH_CENTER | c4d.BFV_CENTER, it's still appearing at the top left of its parent group.
      2. I'd like "Thumbnail 1"'s parent to be a square. My initial width and height are set using initw=160, inith=160 but it's still rectangular.
      3. I'd like the text "Thumbnail 1" to be at the horizontal center and vertical bottom of its parent. I am using the flags: c4d.BFH_CENTER | c4d.BFV_BOTTOM
      Can anyone help me with these issues, please? My code is below. Thank you.
      from c4d import utils
      from c4d.gui import GeUserArea, GeDialog
      UIID01 = 10001
      UIID02 = 10002
      UIID03 = 10003
      UIID04 = 10004
      UIID05 = 10005
      UIID06 = 10006
      class Dialog(GeDialog):
          def __init__(self):
              super(Dialog, self).__init__()
          def CreateLayout(self):
              self.SetTitle("My GUI")
              #column 1
              self.GroupBegin(id=UIID01,flags=c4d.BFH_SCALEFIT, cols=1, rows=2, title="") #2
              self.GroupBorderNoTitle(c4d.BORDER_SCHEME_EDIT)
              #column 1 row 1, Title
              self.GroupBegin(id=UIID02,flags=c4d.BFH_SCALEFIT, cols=1, rows=1, title="", inith=50) #4
              self.GroupBorderNoTitle(c4d.BORDER_BLACK)
              self.AddStaticText(UIID03, c4d.BFH_CENTER | c4d.BFV_CENTER , name="TITLE", borderstyle=1)
              self.GroupEnd() #4
              #column 1 row 2, Scroll List
              self.ScrollGroupBegin(id=UIID04, flags=c4d.BFH_SCALEFIT, scrollflags=c4d.SCROLLGROUP_VERT, inith=260) #4
              #thumbnail
              self.GroupBegin(id=UIID05, flags=c4d.BFH_LEFT | c4d.BFV_TOP, cols=1, rows=1, title="", initw=160, inith=160) #5
              self.AddStaticText(UIID06, c4d.BFH_CENTER | c4d.BFV_BOTTOM , name="Thumbnail 1")
              self.GroupEnd() #5
              self.GroupEnd() #4, end Scroll List
              self.GroupEnd() #2, end column 1
      def main(doc):
          dlg = Dialog()
          dlg.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, defaultw=640, defaulth=640)
          main(doc)
        It was indeed a bit tricky
        1. If you only input BFH_CENTER | c4d.BFV_CENTER you don't tell the gadget to actually take the whole space, so you need to also specify BFH_SCALE | c4d.BFV_SCALE.
        2. All sizes passed in GeDialog Gadget creation should be coming from c4d.gui.SizePix to get correct data. (I will add information about it in the python documentation)
        3. Same as the first point.
        Here you are with a working solution.
        MAIN_GROUP = 10001
        MAIN_TOP_GROUP = 10002
        TOP_GROUP_TITLE = 10003
        MAIN_BOTSCROLL_GROUP = 10004
        MAIN_THUMBNAIL_GROUP = 10005
        THUMBNAIL_TEXT = 10006
            def __init__(self):
                # column 1
                if self.GroupBegin(id=MAIN_GROUP,flags=c4d.BFV_SCALEFIT | c4d.BFH_SCALEFIT, cols=1, rows=1, title=""):
                    self.GroupBorderSpace(2, 2, 2, 2)
                    # column 1 row 1, Title
                    if self.GroupBegin(id=MAIN_TOP_GROUP,flags=c4d.BFV_CENTER | c4d.BFH_SCALEFIT , cols=1, rows=1, title="", inith=c4d.gui.SizePix(50)):
                        self.AddStaticText(TOP_GROUP_TITLE, c4d.BFV_CENTER | c4d.BFV_SCALE | c4d.BFH_CENTER | c4d.BFH_SCALE, name="TITLE", borderstyle=1)
                    self.GroupEnd()
                    if self.ScrollGroupBegin(id=MAIN_BOTSCROLL_GROUP, flags=c4d.BFH_SCALEFIT, scrollflags=c4d.SCROLLGROUP_VERT | c4d.SCROLLGROUP_NOVGAP, inith=c4d.gui.SizePix(200)):
                        self.GroupBorderSpace(10, 10, 2, 2)
                        #thumbnail
                        thumbSize = c4d.gui.SizePix(160)
                        if self.GroupBegin(id=MAIN_THUMBNAIL_GROUP, flags=c4d.BFH_LEFT | c4d.BFV_TOP, cols=1, rows=1, title="", initw=thumbSize, inith=thumbSize):
                            self.GroupBorderSpace(2, 2, 2, 7)
                            self.AddStaticText(THUMBNAIL_TEXT, c4d.BFV_BOTTOM | c4d.BFV_SCALE | c4d.BFH_CENTER | c4d.BFH_SCALE, name="Thumbnail 1")
                        self.GroupEnd()
                    self.GroupEnd()
                self.GroupEnd()
        def main(doc):
            dlg = Dialog()
            main(doc)
        ? 1 Reply Last reply Reply Quote 2
        • ? Offline
          A Former User @m_adam
          @m_adam You are a legend!
          I've learned a lot about UI in Cinema 4D from this post, thank you very much.
          • ? Offline
            A Former User
            This post is deleted!
