    R21 BaseDraw::DrawPointArray draws squares versus circles in R20
    c++r20r21
    4 Posts 2 Posters 617 Views 2 Watching
    • C4DSC Offline
      C4DS
      I have yet again a strange behaviour with R21 which I cannot seem to explain.
      As always a sample implementation is provided below (without any optimization nor sanity checking)
      Same code copied into a R21 plugin and R20 plugin provide different results, see screenshot.
      I seem to remember having had the same issue on a Mac Mini running R16 (if I remember correctly). Where the Windows implementation resulted in circular dots, while the Mac displayed square dots. Back then, I assumed it was related to the fact the Mac Mini was using an Intel CPU graphic display, while the Windows machine had a NVidia Geforce 920m running.
      However, the R20 and R21 testing is done one the same Windows machine, running next to each other in their respective Visual Studio debug session.
      I am trying to think and guess what might be wrong in the R21 implementation, but I just cannot figure out what is missing. I simply copied the whole code, ran it in R20 ... and there all is OK.
      // Cinema 4D C++ plugin
      // PluginName: Test
      // Dummy "empty" plugin
      // Main.cpp
      #include "c4d.h"
      // Dummy IDs - for demonstration purposes only
      #define MYSCENEHOOK_PLUGIN_ID	1000000
      // SceneHook
      class MySceneHook : public SceneHookData
      	INSTANCEOF(MySceneHook, SceneHookData)
      	MySceneHook();
      	virtual Bool Draw(BaseSceneHook *node, BaseDocument *doc, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt, SCENEHOOKDRAW flags);
      	static NodeData *Alloc(void) { return NewObjClear(MySceneHook); }
      MySceneHook::MySceneHook() : SceneHookData()
      Bool MySceneHook::Draw(BaseSceneHook *node, BaseDocument *doc, BaseDraw *bd, BaseDrawHelp *bh, BaseThread *bt, SCENEHOOKDRAW flags)
      	if (!node || !doc || !bd || !bh)
      		return false;
      	if (flags != SCENEHOOKDRAW::DRAW_PASS)
      		return true;
      	Int32 lLeft, lTop, lRight, lBottom;
      	bd->GetFrame(&lLeft, &lTop, &lRight, &lBottom);
      	bd->SetMatrix_Screen();
      	const Int32 pointCount = 5;
      	for (Int32 i = 0; i < pointCount; ++i)
      		Float pointSize = 10.0 * i;
      		bd->SetPointSize(pointSize);
      		iferr(Vector32* vPoints = NewMem(Vector32, pointCount))
      			return false;
      		vPoints[0] = Vector32(i * 50.0 + (lLeft + lRight) * 0.5, (lTop + lBottom) * 0.5, 0.0);
      		const Vector selprevColor = GetViewColor(VIEWCOLOR_SELECTION_PREVIEW);
      		bd->SetPen(selprevColor);
      		bd->DrawPointArray(pointCount, vPoints);
      		DeleteMem(vPoints);
      	// restore basedraw matrix
      	bd->SetMatrix_Matrix(nullptr, Matrix());
      	return true;
      // Plugin Main
      Bool PluginStart(void)
      	ApplicationOutput("Test"_s);
      	RegisterSceneHookPlugin(MYSCENEHOOK_PLUGIN_ID, "MySceneHook"_s, 0, MySceneHook::Alloc, EXECUTIONPRIORITY_GENERATOR, 0);
      	return true;
      void PluginEnd(void)
      Bool PluginMessage(Int32 id, void * data)
      	switch (id) {
      	case C4DPL_INIT_SYS:
      		if (!g_resource.Init())
      			return false;
      		return true;
      	case C4DMSG_PRIORITY:
      		return true;
      	case C4DPL_BUILDMENU:
      		break;
      	case C4DPL_ENDACTIVITY:
      		return true;
      	return false;
      • C4DSC Offline
        C4DS
        Apologies for the somewhat incorrect code I provided.
        I know notice I had started wanting to draw 5 points, and made an appropriate loop. Then I noticed the point size had to be changed on a per point level, which wasn't possible with a single call to DrawPointArray.
        While the result is still the same, here's the intended code (for the drawing method only, all rest remains as original)
        		return false;
        		return true;
        	const Int32 loopCount = 5;
        	const Int32 pointCount = 1;
        	for (Int32 i = 0; i < loopCount; ++i)
        			return false;
        		DeleteMem(vPoints);
        	return true;
          hello,
          To keep you inform, I'm asking the devs and this is taking more time than expected. Sorry for the delay.
            Hello
            Sorry for the delay, Christmas time didn't helped.
            I've opened a bug entry for that issue.
            I'll be back when i'll have more information.
            I've added the "Bug report" tag to this thread
