    Failed to get data from BaseContainer
    r21c++
    3 Posts 2 Posters 502 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      I use the plugin to store some data to the Base Container, but it always crashes when I read it again from the Base Container.
      return ...ge_container.h(293): CRITICAL: Stop
      Thanks for any help!
      this is code
      //function ToBc
      static maxon::Result<void> ToBC(BaseContainer& bc_local_pos,maxon::BaseArray<maxon::BaseArray<maxon::BaseArray<Vector>>>& local_pos)
      	//Convert a 3 dimensions BaseArray to a 3 dimensions BaseContainer
      	Int32 all_cnt = local_pos.GetCount(), i,x = 0,x_id ;
      	for (i = 0;i < all_cnt;++i)
      		BaseContainer per_bc_local_pos;
      		Int32 per_local_cnt = local_pos[i].GetCount(), l;
      		for (l = 0;l < per_local_cnt;++l)
      			BaseContainer per_per_bc_local_pos;
      			Int32 per_per_local_cnt = local_pos[i][l].GetCount(), p_l;
      			for (p_l = 0;p_l < per_per_local_cnt;++p_l)
      				per_per_bc_local_pos.SetVector(p_l, local_pos[i][l][p_l]);
      			per_bc_local_pos.SetContainer(l, per_per_bc_local_pos);
      			//test
      			BaseContainer test = per_bc_local_pos.GetContainer(l);
      			x = 0;
      			while (true)
      				x_id = test.GetIndexId(x++);
      				if (x_id == NOTOK)
      					break;
      				else
      					Vector vec = test.GetVector(x_id);
      					DiagnosticOutput("Vector:@", vec);
      		bc_local_pos.SetContainer(i, per_bc_local_pos);
      	return maxon::OK;
      //function ToArr
      static maxon::Result<void> ToArr(BaseContainer& bc_local_pos, maxon::BaseArray<maxon::BaseArray<maxon::BaseArray<Vector>>>& local_pos)
      	//convert 3 dimensions BaseContainer to 3 dimensions BaseArray
      	iferr_scope;
      	Int32 x = 0, y = 0, z = 0;
      	x = 0;
      	while (true)
      		const Int32 x_id = bc_local_pos.GetIndexId(x++);
      		if (x_id == NOTOK)
      			break;
      		else
      			BaseContainer per_bc_local_pos = bc_local_pos.GetContainer(x_id);
      			maxon::BaseArray<maxon::BaseArray<Vector>> per_local_pos;
      			y = 0;
      			while (true)
      				const Int32 y_id = per_bc_local_pos.GetIndexId(y++);
      				if (y_id == NOTOK)
      					break;
      				else
      					BaseContainer per_per_bc_local_pos = per_bc_local_pos.GetContainer(y_id);
      					z = 0;
      					maxon::BaseArray<Vector> per_per_local_pos;
      					while (true)
      						const Int32 z_id = per_per_bc_local_pos.GetIndexId(z++);
      						if (z_id == NOTOK)
      							break;
      						else
      							per_per_local_pos.Append(per_per_bc_local_pos.GetVector(z_id)) iferr_return;
      					per_local_pos.Append(per_per_local_pos) iferr_return;
      			local_pos.Append(per_local_pos) iferr_return;
      	return maxon::OK;
      //    local_pos, new_local_pos ----> 3 dimension BaseArray<Vector>
      //    test_bc ----> BaseContainer
      ToBC(test_bc, local_pos)
      ToArr(test_bc,new_local_pos)
      相信我,可以的!
      • r_giganteR Offline
        r_gigante
        Hi chuanzhen, thanks for reaching out us.
        With regard to the issue reported, I'm not able to hit the Critical Stop mentioned in the initial post.
        I've tested your code using
        	maxon::BaseArray<maxon::BaseArray<maxon::BaseArray<maxon::Vector>>> ba_3d, ba_3d2;
        	ba_3d.Resize(2) iferr_return;
        	ba_3d[0].Resize(2) iferr_return;
        	ba_3d[1].Resize(2) iferr_return;
        	ba_3d[0][0].Resize(2) iferr_return;
        	ba_3d[0][1].Resize(2) iferr_return;
        	ba_3d[1][0].Resize(2) iferr_return;
        	ba_3d[1][1].Resize(2) iferr_return;
        	ba_3d[0][0][0] = maxon::Vector(0, 0, 0);
        	ba_3d[0][0][1] = maxon::Vector(0, 0, 1);
        	ba_3d[0][1][0] = maxon::Vector(0, 1, 0);
        	ba_3d[0][1][1] = maxon::Vector(0, 1, 1);
        	ba_3d[1][0][0] = maxon::Vector(1, 0, 0);
        	ba_3d[1][0][1] = maxon::Vector(1, 0, 1);
        	ba_3d[1][1][0] = maxon::Vector(1, 1, 0);
        	ba_3d[1][1][1] = maxon::Vector(1, 1, 1);
        	BaseContainer bc_3d;
        	ToBC(bc_3d, ba_3d) iferr_return;
        	ToArr(bc_3d, ba_3d2) iferr_return;
        	for (int i = 0; i < 2; i++)
        		for (int j = 0; j < 2; j++)
        			for (int k = 0; k < 2; k++)
        				DiagnosticOutput("[@][@][@]: ba_3d -> @\nba_3d2 -> @", i, j, k, ba_3d[i][j][k], ba_3d2[i][j][k]);
        	return maxon::OK;
        and this was the output reported in the console - the lines starting with "Vector:" were from your code -
        Vector:(0.000,0.000,0.000)
        Vector:(0.000,0.000,1.000)
        Vector:(0.000,1.000,0.000)
        Vector:(0.000,1.000,1.000)
        Vector:(1.000,0.000,0.000)
        Vector:(1.000,0.000,1.000)
        Vector:(1.000,1.000,0.000)
        Vector:(1.000,1.000,1.000)
        [0][0][0]: ba_3d -> (0.000,0.000,0.000)
        ba_3d2 -> (0.000,0.000,0.000)
        [0][0][1]: ba_3d -> (0.000,0.000,1.000)
        ba_3d2 -> (0.000,0.000,1.000)
        [0][1][0]: ba_3d -> (0.000,1.000,0.000)
        ba_3d2 -> (0.000,1.000,0.000)
        [0][1][1]: ba_3d -> (0.000,1.000,1.000)
        ba_3d2 -> (0.000,1.000,1.000)
        [1][0][0]: ba_3d -> (1.000,0.000,0.000)
        ba_3d2 -> (1.000,0.000,0.000)
        [1][0][1]: ba_3d -> (1.000,0.000,1.000)
        ba_3d2 -> (1.000,0.000,1.000)
        [1][1][0]: ba_3d -> (1.000,1.000,0.000)
        ba_3d2 -> (1.000,1.000,0.000)
        [1][1][1]: ba_3d -> (1.000,1.000,1.000)
        ba_3d2 -> (1.000,1.000,1.000)
        Two things to mention:
        • the Critical Stop you hit is caused by the fact that the BaseContainer::GetContainer() method is attempted to run on an entry which is actually not containing a BaseContainer.
        • if you need to simply transfer the content of a BaseArray to a BaseContainer you can consider to use BaseContainer::SetMemory() as shown in in the BaseContainer Manual.
        • finally I recommend rewriting your method signatures ordering the parameters and taking advantage of the const qualifier as:
        static maxon::Result<void> ToBC(const maxon::BaseArray<maxon::BaseArray<maxon::BaseArray<Vector>>>& local_pos, BaseContainer& bc_local_pos)
        static maxon::Result<void> ToArr(const BaseContainer& bc_local_pos, maxon::BaseArray<maxon::BaseArray<maxon::BaseArray<Vector>>>& local_pos)
        Best, Riccardo
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @r_gigante
          Hi, @r_gigante
          Thank you for your reply. With your help, I finally traced the source of the problem. As you said, the reason for the error(Critical Stop) is that there is no Container at all. Because of a very hidden error in somewhere, I wrote the wrong data type to BaseContainer.
          相信我,可以的!
