    Undefined symbols
    r21sdk
    12 Posts 5 Posters 1.6k Views 2 Watching
    • R Offline
      rui_mac
      Actually, yes.
      Would it be better to use GePrint?
      Or was it discontinued?
      What is the best way to print to the Console now, in C++?
      • C4DSC Offline
        C4DS @rui_mac
        @rui_mac said in Undefined symbols:
        ApplicationOutput() If you mean the Cinema4D console, that is.
        • r_giganteR Offline
          r_gigante
          Hi Rui, thanks for reaching out us.
          With regard to the mentioned issued, it's pretty clear looking at the outputted line in the building log that you were trying to feed some function with a data-type missing the ToString() method which is usually supposed to "convert" the data in a convenient maxon::String representation.
          I warmly recommend to have a look at the Conversion section in the maxon::String Manual.
          Last but not least this change was already requested to adapt code from R19 to R20 and not from R20 to R21.
          Best, R
          • kbarK Offline
            kbar
            You can still use DiagnosticOutput. The comments from the code I pasted above said the following... did you try this?
            “you must #include "maxon/string.h" in that source file to fix it.”
            https://www.plugins4d.com
            • R Offline
              rui_mac
              I still get the same error, even after adding the #include "maxon/string.h"
              I also replaced the DiagnosticOutput() with ApplicationOutput(), but the error persists.
              • kbarK Offline
                kbar
                Thanks for checking, I was interested to know if that was your problem or not.
                I will leave you in the hands of the SDK team.
                  r_gigante
                  Hi rui_mac, might you kindly consider sharing a snippet to reproduce the issue?
                  Thanks, R
                  • R Offline
                    rui_mac
                    Since it is my serial protection code, I may have to edit things a bit, to protect my secrets 😉
                    I will see if I can adjust to code to provide as much information as possible, without revealing too much, as soon as I get home.
                      If you prefer in order to not disclose confidential stuff you can contact us by email at [email protected].
                      • R Offline
                        rui_mac
                        Great, I will do that. 🙂
