    String to ASCII value and vice-versa.
    sdkr21
    4 Posts 3 Posters 537 Views
    • R Offline
      rui_mac
      This is for C++.
      I have a String variable containing alphanumerical characters.
      How can I get the ASCII value of each character?
      For example, if my String variable is "a1b2", how can I get the ASCII values of each character (97,49,98,50)?
      And, if I have an Int32 variable containing a numerical value, how can I create a String out of that ASCII value.
      For example, if my Int32 variable has a value of 102, how can I create a String that contains "f" ?
      I have been going through the documentation but these simple conversions, that are so basic in other languages, are not simple to understand in the C++ documentation.
      • C4DSC Offline
        C4DS
        Maybe not the best solution but this seems to work:
        	maxon::String str = "a1b2"_s;
        	Int32 ascii = 102;
        	// convert string to ASCII
        	for (Int32 i = 0; i < str.GetLength(); ++i)
        		char c = (char)str[i];
        		Int32 a = (Int32)str[i];
        		ApplicationOutput("'@' position @ has char @ (ascii = @)", str, i, c, a);
        	// ASCII to string
        		maxon::String ascii2str;
        		ascii2str.AppendChar(ascii);
        		ApplicationOutput("ascii value @ results into string '@'", ascii, ascii2str);
        	// alternative
        		iferr(ascii2str.Insert(0, char(ascii)))
        		ApplicationOutput("(alternative) ascii value @ results into string '@'", ascii, ascii2str);
        Output to console:
        'a1b2' position 0 has char 97 (ascii = 97)
        'a1b2' position 1 has char 49 (ascii = 49)
        'a1b2' position 2 has char 98 (ascii = 98)
        'a1b2' position 3 has char 50 (ascii = 50)
        ascii value 102 results into string 'f'
        (alternative) ascii value 102 results into string 'f'
        • R Offline
          rui_mac
          Thank you very much.
          It seems to work 🙂
          • S Offline
            s_bach
            just FYI: you find information on how to access individual characters from a string in the manual: String Manual
            Also, one of our examples includes checking the ASCII value of a given character: streamconversion_impl.cpp
            If your question has been answered, please mark your thread as a question and set it to "solved".
