    Prevent c4d from opening path passed in sys.argv
    r20pythonwindows
    5 Posts 2 Posters 1.0k Views 1 Watching
    • B Offline
      Boony2000
      Hi!
      I want to do pretty much what was proposed in this thread. That is passing a script via sys.argv.
      It seems that Cinema is trying to load the file after I'm done with my stuff and since it doesn't recognize the filetype I get an error "Unrecognized file format!".
      I tried consuming the path with sys.argv.remove(path), but that didn't really seem to do anything.
      How can I prevent Cinema from attempting to open the path?
      Thanks!
        Hi @Boony2000 unfortunately, Python can't consume/remove arguments.
        But you could either add a variable so this way Cinema 4D will not try to load your file with something like
        Cinema 4D.exe g_myvariable="filePath".
        • B Offline
          Boony2000
          Hi Maxime!
          Thanks for your answer.
          Is there a way to directly get that variable in Cinema, or is it basically just modifying the string into something that isn't recognized by Cinema? For me it looks like I now have to seperate the string by finding the '=' or something like that. Is that what I have to do?
            You can use the argparse module.
            Find an example Commandline.py.
            • B Offline
              Boony2000
              Thanks! I'll try that.
