    First R21 plugin ... memory leaks and dangling references
    r21c++
    13 Posts 2 Posters 2.0k Views 2 Watching
    • r_giganteR Offline
      r_gigante
      Hi Daniel, thanks for reaching out us.
      I'm pretty surprised to see this sort of issue popping out since from our test we never encountered such case.
      Can you confirm that:
      • you created a proper projectdefinition.txt and created IDE projects out of it?
      • can you confirm that no other plugins were loaded by Cinema when the leak occurred?
      • can you confirm that it happens with no plugins at all loaded?
      • can you provide you OS/IDE configuration?
      Looking at the log I'm a bit surprised to see leaks in the kernel framework about OpenGL methods in the drawport. Is your machine provided with updated GPU drivers?
      Sorry for the dumb questions, but this might help us to do some better differential analysis.
      Cheers, Riccardo
      • C4DSC Offline
        C4DS
        I am surprised as well to see these issue, as I figure I wouldn't be the only one if this were genuine memory leaks. I can only assume something went wrong during my setup of the SDK.
        I have started afresh and have extracted the R21 SDK on my D drive at
        D:\Projects\Dev\SDK_R21
        There a subfolder named "frameworks" has been created with the content of the SDK.zip
        Also inside D:\Projects\Dev\SDK_R21 I have a "plugins" folder, which only contains the extracted "cinema4dsdk" folder (I removed maxonsdk.module and microsdk), and a "project" folder, which contains the solution projectdefinition.txt as follows
        Platform=Win64;OSX
        Type=Solution
        Solution=\
        	plugins/cinema4dsdk
        I downloaded the projecttool (20190903) and extracted this into
        D:\Projects\Dev\SDK_R21, which created a "cinema4d_r21_project_tool_20190903" folder.
        In D:\Projects\Dev\SDK_R21 I created a bat file to execute the projecttool, as follows:
        d:\Projects\dev\SDK_R21\cinema4d_r21_project_tool_20190903\kernel_app_64bit.exe g_updateproject=d:\Projects\dev\SDK_R21\plugins\project
        I execute this batch file, which generates the plugins solution, which I double click, opening Visual Studio 2017.
        I make cinema4dsdk the startup project, enter the Cinema4D executable into the project's debugging properties. Build all (debug, 64bit), start debugging, wait for Cinema 4D to launch, close cinema ... and get the list of memory leaks and dangling references.
        As I didn't add a specific plugin folder to the build project, nor did I manually install any plugin, I can confirm there are no plugins available in the Extension menu of Cinema4D.
        Windows 10, 64 bit, Professional Edition (build 18362)
        4(8)x Intel Core i5-8259U CPU, CPU speed 2310.000
        Visual Studio Express 2017 for Windows Desktop Version 15.9.15
        Microsoft .NET Framework 4.8.03752
        • C4DSC Offline
          C4DS
          OK, so I went over it once more.
          Step 1.
          Deleted the whole SDK_R21 folder, and extracted the sdk.zip to
          Step 2
          Extracted the project tool
          Step 3
          created and executed a batch file to create the necessary project files for the frameworks
          d:\Projects\dev\SDK_R21\cinema4d_r21_project_tool_20190903\kernel_app_64bit.exe g_updateproject=d:\Projects\dev\SDK_R21\frameworks
          Step4
          created and executed a batch file for the plugins
          Step 5
          created and executed a batch file for the plugin solution
          (This batch file will be used when plugins are added, in order to update the plugins solution)
          Step 6
          Double click the created plugin.sln, which opens Visual Studio.
          Step 7
          Build the whole solution, which results in errors for every vcxproj, as it mentions that Windows SDK version 8.1 was not found. Since running on Windows 10 I retarget all the projects ... Visual Studio offers the available Windows SDK 10.0.17763.0
          I do this for every framework and plugin in the solution.
          Step 8
          Rebuild whole solution -> no more build errors.
          Step 9
          I set the cinema4dsdk as startup project, add the Cinema4D executables as debugging property
          Step 10
          Launch debugger, wait for Cinema 4D to launch, open the console (Shift-F10), close Cinema 4D ...
          Result: ALL GOOD, no memory leaks, no dangling references.
          Pffewh! Now I am finally settled, ready to start.
          I don't know what went wrong the first and second time, and I am not trying to figure out.
          • C4DSC Offline
            C4DS
            Spoke too soon !!!
            The moment I add g_alloc=Debug as Command Arguments of the debugging properties to any of the plugins, I do get the same list of memory leaks and dangling references .
            I remember that entry from the time working on R20 and previous releases ... is this not applicable for R21 anymore?
            Additionally, every plugin I add to the solution requires me to retarget from Windows 8.1 SDK to the Windows 10 SDK, since the R8.1 isn't installed. Is this 8.1 SDK reference a default of the project tool?
            Since Cinema only runs on Windows 10, and plugins thus should be using Windows 10 SDK, why this obsolete 8.1 ?
              r_gigante
              Hi Daniel,
              thanks for the throughful description, but I'm not able to reproduce the leak.
              The steps I used are:
              1. unzip the sdk.zip coming with Cinema 4D R21 installation (let say in D:\AppsRepository\MAXON\SDKs\21.022_RB288344_RC)
              2. unzip the projecttool (lets say in D:\AppsRepository\MAXON\ProjectTool\20190903_R21RC_projecttool)
              3. execute D:\AppsRepository\MAXON\ProjectTool\20190903_R21RC_projecttool\kernel_app_64bit.exe g_updateproject=D:\AppsRepository\MAXON\SDKs\21.022_RB288344_RC (this single string will create projects for frameworks, plugins and the whole solution file, it's not recommended to run it three separate times)
              4. open the solution with VS2017 and just build (I actually didn't changed the Windows SDK Version)ee2c9f40-210e-4cec-a619-1394c16523b3-image.png
              5. set the proper cmdline args as from below picture
              6. Press F5 in VS2017 to start debug
              7. Upon Cinema start, open the Console (Shift-F10)
              8. Quit Cinema
              I didn't had the need to change anything in the solution settings, everything was built out-of-the-box as much as it's supposed to happen.
              Could you please try to reproduce the issue with the steps above?
              Thanks, Riccardo
              • C4DSC Offline
                C4DS
                Hi Riccardo,
                I had installed Visual Studio 2017 Desktop Express, and wasn't able to add the Windows 8.1 SDK during installation due to limited settings being available. So, I uninstalled that one, and instead downloaded the Visual Studio 2017 Community Edition.
                Reinstalled all, making sure the Windows 8.1 SDK option was enabled.
                Removed the whole SDK folder and extracted once more, completely afresh. Same for the project tool.
                I then launched the project tool with the command as you listed (once). Double clicked the solution, and built everything. Now with the Windows 8.1 SDK present I didn't have to retarget every project ... nice!
                However, when pressingn F5:
                Without the "g_alloc=debug" in the debugging options all runs fine, and after quiting Cinema4D no issues are listed. But, when I add the debugging option I still get the same list of memory leaks and dangling references.
                Unfortunately, no progress.
                  r_gigante
                  Hi Daniel,
                  I've created your same setup in a Virtual Window 10 environment and I had no good luck in replicating this.
                  Can you share your GPU specs and drivers revision information? With this info I can have a look around to see if any of our QA or developers have experienced something similar.
                  Best, Riccardo
                  • C4DSC Offline
                    C4DS
                    Here's a dump from DxDiag:
                    System Information
                          Time of this report: 9/19/2019, 21:45:45
                                 Machine name: NUC
                             Operating System: Windows 10 Pro 64-bit (10.0, Build 18362) (18362.19h1_release.190318-1202)
                                     Language: English (Regional Setting: English)
                          System Manufacturer: Intel(R) Client Systems
                                 System Model: NUC8i5BEH
                                         BIOS: BECFL357.86A.0064.2019.0213.1122 (type: UEFI)
                                    Processor: Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz (8 CPUs), ~2.3GHz
                                       Memory: 32768MB RAM
                          Available OS Memory: 32636MB RAM
                                    Page File: 2894MB used, 34606MB available
                                  Windows Dir: C:\Windows
                              DirectX Version: DirectX 12
                          DX Setup Parameters: Not found
                             User DPI Setting: 96 DPI (100 percent)
                           System DPI Setting: 96 DPI (100 percent)
                              DWM DPI Scaling: Disabled
                                     Miracast: Available, with HDCP
                    Microsoft Graphics Hybrid: Not Supported
                     DirectX Database Version: Unknown
                               DxDiag Version: 10.00.18362.0267 64bit Unicode
                    Display Devices
                               Card name: Intel(R) Iris(R) Plus Graphics 655
                            Manufacturer: Intel Corporation
                               Chip type: Intel(R) Iris(R) Plus Graphics Family
                                DAC type: Internal
                             Device Type: Full Device (POST)
                              Device Key: Enum\PCI\VEN_8086&DEV_3EA5&SUBSYS_20748086&REV_01
                           Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
                     Device Problem Code: No Problem
                     Driver Problem Code: Unknown
                          Display Memory: 16446 MB
                        Dedicated Memory: 128 MB
                           Shared Memory: 16318 MB
                            Current Mode: 1920 x 1200 (32 bit) (59Hz)
                             HDR Support: Not Supported
                        Display Topology: Internal
                     Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
                         Color Primaries: Red(0.673828,0.319336), Green(0.187500,0.706055), Blue(0.148438,0.064453), White Point(0.313477,0.329102)
                       Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
                            Monitor Name: Generic PnP Monitor
                           Monitor Model: DELL 2408WFP
                              Monitor Id: DELA02C
                             Native Mode: 1920 x 1200(p) (59.950Hz)
                             Output Type: HDMI
                    Monitor Capabilities: HDR Not Supported
                    Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
                          Advanced Color: Not Supported
                             Driver Name: C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_bf9afe57cbde0e11\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_bf9afe57cbde0e11\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_bf9afe57cbde0e11\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_bf9afe57cbde0e11\igd12umd64.dll
                     Driver File Version: 26.20.0100.6912 (English)
                          Driver Version: 26.20.100.6912
                             DDI Version: 12
                          Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
                            Driver Model: WDDM 2.6
                     Graphics Preemption: Triangle
                      Compute Preemption: Thread
                                Miracast: Supported
                          Detachable GPU: No
                     Hybrid Graphics GPU: Integrated
                          Power P-states: Not Supported
                          Virtualization: Paravirtualization
                              Block List: No Blocks
                      Catalog Attributes: Universal:False Declarative:True
                       Driver Attributes: Final Retail
                        Driver Date/Size: 28/05/2019 02:00:00, 1887728 bytes
                             WHQL Logo`d: n/a
                         WHQL Date Stamp: n/a
                       Device Identifier: {D7B78E66-7DE5-11CF-36F8-1000BAC2D735}
                               Vendor ID: 0x8086
                               Device ID: 0x3EA5
                               SubSys ID: 0x20748086
                             Revision ID: 0x0001
                      Driver Strong Name: oem4.inf:5f63e5341264f0f6:iCFL_w10_DS:26.20.100.6912:PCI\VEN_8086&DEV_3EA5
                    Extra note:
                    I now only have the included plugin projects in the solution, and use cinem4dsdk as startup project. No other plugins of mine are part of the solution.
                    This whole issue reminds me about this:
                    https://developers.maxon.net/forum/topic/11212/memory-leak-after-plugin-migration-r16-r20
                    Same situation, memory leaks not reproducible.
                    • C4DSC Offline
                      C4DS
                      Warning: long and endless background drivel ahead ...
                      As mentioned before until R21 I was developing plugins on a laptop running Windows 8.1 and VS2015.
                      This laptop has an integrated nVidia Geforce 920m, next to the onboard Intel Graphics.
                      In the past I had upgraded to Windows 10 but didn't find acceptable stable video drivers and had to revert back after numerous crashes of the OS.
                      So, I kept using Windows 8.1. Which is the reason I couldn't install R21 and start developing. I thus purchased a new machine, and kept it simple: an Intel NUC having an 8th generation i5 CPU with integrated Intel Iris Plus Graphics 655. No dedicated graphics card, as I didn't plan on using this machine for 3D content creation, only for development purposes, and other less graphic related chores.
                      On the "old laptop" I kept developing for R20, and ported the code to R21 on "the NUC".
                      Due to some eID install mishap on the laptop I lost my dedicated graphics car and needed to figure out how to resolve this. In the meantime I reverted to using the integrated intel graphics for further development. It is at this point in time I discovered that on this trusty and rusty laptop I also started to experience the memory leaks I encountered on the NUC.
                      I was finally able to resolve the nVidia graphics issue and regained access to the dedicated graphics card (food for another story, I am sure).
                      Surpisingly, as soon as I was using the nVidia again I didn't encounter any memory leaks ... without any changes, except for activating the nVidia in the laptops' BIOS.
                      Now, I cannot try and do the same on the NUC, since it cannot accept any additional hardware (except eGPU ... which I am "budgetly" not enabled to access). I expect the same would be true for that machine. As soon as it would have a dedicated GPU it would be freed from all these memory leaks.
                      Question is now if these are actual memory leaks, or if these are "fake" reports from Visual Studio?
                      Anyway, the issue I had seems to be resolved.
                      I am not changing the status of this topic to "SOLVED" as I feel the issue isn't exactly solved.
                      For anyone running a system without dedicated GPU the issue will probably still be an issue.
                      I now understand why all you guys couldn't reproduce the issue in the first place. You probably have all kick-ass systems running heavy duty graphic cards.
                        r_gigante
                        Thanks Daniel for the extensive following up.
                        I'll check with our QA if there's a machine without a discrete graphic card in our testing environment that could confirm your issue. At the same time I'll rise attention of our viewport engineers on the topic.
                        Best, R.
                          r_gigante
                          Hi Daniel,
                          I just wanted to inform you that QA has been able to reproduce the issue. I've filed a bug report (ITEM#306240) and hope this to get solved soon.
                          Cheers, R
                          C4DSC 1 Reply Last reply Reply Quote 1
                          • C4DSC Offline
                            C4DS @r_gigante
                            @r_gigante
                            Thanks for the feedback.
                            FYI, this wasn't only with R21, had the same issue with R20, since the "old laptop" was restricted to R20 only. But I guess no updates will follow for R20 anymore.
