    Preventing SetDocumentData from switching to active tool
    pythonr20windows
    5 Posts 2 Posters 885 Views 1 Watching
    • B Offline
      Boony2000
      Hi!
      I am trying to change some stuff in reaction to the user changing settings.
      To do that I catch c4d.EVMSG_CHANGE and change some document settings via SetDocumentData.
      The problem I encountered is that SetDocumentData seems to switch the attribute editor to the active tool after it's done.
      That means I can't get to any other attributes, because e.g. selecting an object triggers SetDocumentData and switches back from the object settings to the tool.
      Maybe c4d.EVMSG_CHANGE is a little overkill to detect changes, but I don't know a better way.
      How do I stop SetDocumentData from switching what is shown in the attribute editor?
      Or if that's not possible how can I change something like the document framerate in reaction to something the user does?
        I cannot reproduce this on R20. I used the following code:
        # Main function
            bc = c4d.BaseContainer()
            bc[c4d.DOCUMENT_FPS] = 42
            doc.SetDocumentData(c4d.DOCUMENTSETTINGS_GENERAL , bc)
        # Execute main()
        The attribute editor kept the document settings node selected. Could you shed some more light on your code / provide a snippet?
        If it is only the documents frame rate you are after, BaseDocument has the members GetFps() and SetFps().
        zipit
        • B Offline
          Boony2000
          Interesting. What I was doing is this:
          fps = 25
          docSettings = doc.GetDocumentData(c4d.DOCUMENTSETTINGS_GENERAL)
          docSettings[c4d.DOCUMENT_FPS] = fps
          doc.SetDocumentData(c4d.DOCUMENTSETTINGS_GENERAL, docSettings)
          Which does cause the problem even if directly entered via the python console.
          I don't know why that is bad exactly. At this point I was only changing the FPS, at another place a bunch of other stuff. It seemed logical to do it this way. Is using the get/set functions the better way to do that?
            when you overwrite all values of the general settings sub container, you also overwrite DOCUMENT_MODE (which probably causes the behavior you did encounter). You can just overwrite the specific values you need, like I have shown in my example.
            zipit
            • B Offline
              Boony2000
              I'm just going to go ahead and mark this as solved.
              Either using an empty Basecontainer or the set function solve the problem.
              Thank you for explaining!
