    plugins folder, now you see me, now you don't.
    16 Posts 4 Posters 12.6k Views 3 Watching
    • C4DSC Offline
      C4DS
      Further testing.
      R20.059
      Step 1.
      • plugins available in <user_prefs>\plugins and copied to D:\R20plugins
      • preferences has paths to both, both checkboxes enabled.
        Relaunch Cinema 4D, which reports colliding pluginIDs in the console window
      Step 2
      • plugins available in <user_prefs>\plugins and in D:\R20plugins
      • preferences has paths to both, <user_prefs>\plugins unchecked, D:\R20plugins checked
        Relaunch Cinema 4D, plugins loaded, no collisions reported in console
      Step 3
      • preferences has paths to both, <user_prefs>\plugins checked, D:\R20plugins unchecked
      Step 4
      • preferences has paths to both, both unchecked
      R21.026
      Step 1
      • plugins available in <user_prefs>\plugins and in D:\R21plugins
        Relaunch Cinema 4D, colliding pluginIDs reported in console
      Step 2
      • preferences has paths to both, <user_prefs>\plugins unchecked, D:\R21plugins checked
      Step 3
      Step 4
      Current results of R21 seem to fit your findings, I must have mixed up results of R21.026 with those of R20.059
      Meaning that, indeed, R20.057 (on one machine) matches with the results of R20.059 (on the other machine), no collisions when duplicate paths.
      However, I don't understand step 3 on R21.026 doesn't report colliding pluginIDs.
      I just don't get it.
      • r_giganteR Offline
        r_gigante
        Hi Daniel, thanks for following up.
        I've reproduced your cases and I warmly encourage you to test them again since I found a few discrepancies.
        • R20.059
          • case 1: behavior confirmed
          • case 2: behavior not confirmed: I got collision since the plugins are loaded by default from the <user prefs>/plugins folder (even though unchecked) and from the <whatever>/R20plugins folder still checked in the search path. This behavior is consistent with the finding in my previous post since R20.xxx loads by default anything it finds in the <user prefs>/plugins folder
          • case 3: behavior confirmed
          • case 4: behavior confirmed
        • R21.026
          • case 1: behavior confirmed although I see two collisions for every plugin. This is correct since Cinema loads the plugins 3 times, the first by default from <user prefs>/plugins, the second because of the presence of the <user prefs>/plugins in the search path, the third because of the presence of the <whatever>/R21plugins in the search path
          • case 2: behavior confirmed
          • case 3: behavior not confirmed: I got collision since the plugins are loaded by default from the <user prefs>/plugins folder (even though unchecked) and from the <user prefs>/plugins folder still checked in the search path. This behavior is consistent with the finding in my previous post since R21.xxx doesn't exclude the <user prefs>/plugins folder if is specified in the search path
        Finally with regard to
        However, the recommendations for plugin installation is quite a surprise, in particular the second bullet:
        "do not install a plugin in the Cinema 4D user's preferences folder".
        That is exactly the location where the plugin folder gets created at first launch of the application, so I am confused this location is not recommended.
        we think that plugins preferences or user-dependent plugin files might be stored in the <user prefs>/plugins while the actual plugin should be stored in a more convenient location. Last but not least although not planned in the short future, the <user prefs> folder might change in structure and location (usually it depends on OS) and this might cause side effects to plugins stored over there.
        Best, Riccardo
        • C4DSC Offline
          C4DS @r_gigante
          @r_gigante
          Tested again, same results.
          R20.059
          case 2: <user_prefs>\plugins unchecked, D:\R20plugins checked
          -> restart -> no collision
          R21.026
          case 3: <user_prefs>\plugins checked -> no collision.
          I really don't get this as I remember having had collisions when I first tried this.
          I have tried following:
          Removed all paths from the preferences, restart Cinema 4D. Obviously, plugins are loaded due to the default folder, and no collisions since no other path is defined.
          I then add the <user_prefs>\plugin folder again, checkbox enabled. Restart -> no collisions.
          Went a step further:
          I had the <user_prefs>\plugins folder added, then added the <user_prefs> folder (without the "plugins" subfolder) -> restart -> no collision
          Went even crazier:
          With above 2 paths available (and enabled), I added D:\R21plugins
          -> restart -> collisions !!!
          Final case:
          removed the D:R21plugins, then copied the plugins in the <user_prefs>
          resulting in
          <user_prefs>\plugins - Copy
          Added both paths to the preferences, both enabled -> restart -> collisions
          Removed the copy path from the preferences keeping only <user_prefs>\plugins
          Cannot explain the behavior.
          I think I will stop the whole topic here, it seems to make no sense at all.
            r_gigante
            I'm sorry Daniel you're giving it up here, but I dunno how I can be of any further help. I will ask today to one of the other members of the team to replicate the same steps on his system to see if they are consistent with my findings or yours to grant information correctness for those coming in the future and reading the post.
            Best, R.
              hello,
              I've tested with R20.059 and 21.026 and the behavior are the same than @r_gigante. (we talked about it to be sure)
              • C4DSC Offline
                C4DS @r_gigante
                @r_gigante
                I am not actually giving up, just mentioning that it doesn't seem to make sense pursuing with this topic. As it seems we're not experiencing the same behaviour, as if we're using a different version (although it seems to be the same version number) or we're performing different actions.
                Now, I added a new plugin and could not reproduce my previous result with R20.059, as it now always seem to collide whatever I try.
                However, with R21 -which was mentioned should always collide- ... well now I get no collisions. According to the printscreen I made you can notice the only path added to the preferences is the <user_prefs>\plugins, exactly the same as the "internal default", still the console shows no collisions.
                According to both of you, this is not reproducible at your end. Still I am getting this result. I must then have done something differently than both of you?
                Note, the screenshot is right after launching Cinema 4D, and opening the console window and the preference window. No changes performed, simply opening the windows.
                  hello,
                  with the same parameters, I got collision. Would it be possible to test with our sdk ?
                  (it should not be different but at least you would test with the same plugin than us)
                  • C4DSC Offline
                    C4DS @Manuel
                    @m_magalhaes
                    I have built the sdk samples and copied the res folder and the created xdl64 file into
                    C:\Users\Daniel\AppData\Roaming\Maxon\Maxon Cinema 4D R21_64C2B3BD\plugins\sdk
                    Starting Cinema 4D without any paths in the preferences and plugins get loaded. No message in the console.
                    Then adding the path:
                    to the preferences, restarting Cinema 4D ...
                    Plugins get loaded, no message in the console window. Thus no collision.
                      r_gigante
                      Hi Daniel, thanks for following up again.
                      Just to be sure nothing get's neglected I've recorded a video showing that also doing your steps is consistent with what me and Manuel have reported with regard to R21
                      You can see the video here.
                      Best, Riccardo
                      • C4DSC Offline
                        C4DS
                        Thanks for video.
                        I have a slight suspicion about the reason we have different results. Similar to that other discussion point about memory leaks that you guys also can't seem to replicate.
                        But to figure this all out I will need to purchase some extra hardware ... might take a while before I get the funds collected. I will then report back, in both topics.
                        • C4DSC Offline
                          C4DS
                          I now have upgraded the original laptop which was running R20.057, and now have Windows 10.
                          As such with a clean install, I have now R20.059 installed (clean, not updated) and R21.026 (also clean, not updated from 21.022).
                          Both versions have plugins installed in the <user_prefs>/plugins folder. Without any path added to the Cinema 4D preferences they both load the plugins as is.
                          For testing purposes I have added the path to this folder in both releases.
                          With R20.059 I get collisions, which I didn't get with R20.057 on this same laptop running Windows 8.1
                          With R21.026 I do not get collisions
                          I thus experience the same results as those I had with the original installs on "the NUC" (see the memory-leak topic). I had hoped the results would be different, as was clarified by the memory-leak topic, but alas the presence of a dedicated/discrete graphic card has no impact on the result this time.
                          But still, I now have 2 machines which both have clean installs and provide same results as to collisions/no-collisions, and still contradict the results you both have experienced. And this for both R20.059 and R21.026.
                          I am not sure were to go from here?
                            hello,
                            I confirm it's strange.
                            Could you use the g_console=true and g_logfile=d:\logfile.txt as said in this page
                            (both will contain the same lines)
                            Send us the logfile ([email protected]) if you don't want to share that in public.
