    A Curl like POST using NetworkHttpHandlerRef?
    r21c++
    8 Posts 2 Posters 1.4k Views 1 Watching
    • kbarK Offline
      kbar
      Is it possible to do a Curl style post using NetworkHttpHandlerRef?
      I see that it has HandlePost, but so far haven't been successful in getting it working.
      About to compile libCurl with OpenSSL support, but thought I would check here in case I don't need to.
      Thanks!
      Kent
        hello,
        you want to send file or just string data ?
        did you had a look at this manual ?
        • kbarK Offline
          kbar
          Hi Manuel,
          I want to send a HTTP post request with a couple of parameters, which will then return some JSON data.
          I can’t see how to do this from the link you sent. I could open a tcp connection myself to port 80 of my URL, construct and build my own HTTPS header, send it and listen for the returned data.
          The HandlePost function of the NetworkHttpHandlerRef class looks like it was written to do exactly this. But there is no documentation showing how to use it and no examples.
          https://developers.maxon.net/docs/cpp/2023_2/classmaxon_1_1_network_http_handler_interface.html
          I have filled in the DataDictionary with my parameters but when I call HandlePost it always seems to think there is an error in the MAXON result, but it contains no error message telling me what went wrong.
          I would like to call something like this
          curl https://api.myapi.com/v1 -d "product=myproduct" -X POST
          Kent
          • kbarK Offline
            kbar
            This post is deleted!
              hello,
              This should work. memReq will have the returned json file in Ascii.
              After asking the techTeam.
              #include "maxon/network_url.h"  // for HTTP_POSTMETHOD and HTTP_POSTDATA
              #include "maxon/file_utilities.h"
                      iferr_scope;
              	maxon::Url theServer{"http://localhost:8080"_s};
              	maxon::String postData = "foo=bar&bin=go"_s;
              	theServer.Set(maxon::URLFLAGS::HTTP_POSTMETHOD, maxon::HTTPMETHOD::POST) iferr_return;
              	theServer.Set(maxon::URLFLAGS::HTTP_POSTDATA, maxon::CString(postData, maxon::StringEncodings::Utf8())) iferr_return;
              	maxon::BaseArray<maxon::Char> memReq;
              	iferr(maxon::FileUtilities::ReadFileToMemory(theServer, memReq))
              		DiagnosticOutput("@", err);
              	ApplicationOutput("answer @", memReq);
              	maxon::String result(memReq);
              	ApplicationOutput("result @", result);
              	return maxon::OK;
              the simple web server i used this with :
              from BaseHTTPServer import BaseHTTPRequestHandler, HTTPServer
              import SocketServer
              import json
              import cgi
              class Server(BaseHTTPRequestHandler):
                  def _set_headers(self):
                      self.send_response(200)
                      #self.send_header('Content-type', 'application/json')
                      self.send_header('Content-type', 'text/html')
                      self.end_headers()
                  def do_HEAD(self):
                      self._set_headers()
                  # GET sends back a Hello world message
                  def do_GET(self):
                      self._set_headers()
                      self.wfile.write(json.dumps({'hello': 'world', 'received': 'ok'}))
                  # POST echoes the message adding a JSON field
                  def do_POST(self):
                      print 'do post'
                      ctype, pdict = cgi.parse_header(self.headers.getheader('content-type'))
                      form = cgi.FieldStorage(
                          fp=self.rfile,
                          headers=self.headers,
                          environ={'REQUEST_METHOD': 'POST'}
                      print form.getvalue("foo")
                      print form.getvalue("bin")
                      # refuse to receive non-json content
                      if ctype != 'application/x-www-form-urlencoded':
                          self.send_response(400)
                          self.end_headers()
                          print "Can't receive non application/x-www-form-urlencoded content", ctype
                      # send the message back
                      self._set_headers()
                      self.wfile.write(json.dumps(['foo', {'bar': ('baz', None, 1.0, 2)}]))
              def run(server_class=HTTPServer, handler_class=Server, port=8080):
                  server_address = ('', port)
                  httpd = server_class(server_address, handler_class)
                  print 'Starting httpd on port %d...' % port
                  httpd.serve_forever()
                  run()
              • kbarK Offline
                kbar
                Hi Manuel,
                Thanks for the example. That is excellent. For now though I have moved onto using libcurl, but when I come back to this again I will be sure to use this example again. I hope this gets added to the documentation somwhere.
                Kent
                  hello,
                  don't worry, it will.
                  ps : I don't forget the OAuth example neither.
                    hello,
                    i'll be set this thread as resolved tomorrow if nothing to add.
