    Set Knot Value of RangeData, bug?
    r19python
    3 Posts 2 Posters 827 Views 1 Watching
    • G Offline
      gsmetzer
      Hello, I am using a RangeData in my UserData. I am trying to set the value of a knot in the RangeData Gui but nothing is changing despite rs.SetSelectedKnot(knot) returning True.
      Is this a bug or am I doing something wrong? Thanks for any insight.
      (I'm using R19)
         rs = op[c4d.ID_USERDATA,1]   #get my rangeSlider
          v = op[c4d.ID_USERDATA,2]  #Get a Float
          rs.SetCurrentValue(v)
          print rs.GetCurrentValue()
          knot = rs.GetSelectedKnot()
          rs.SetKnotValue(knot, v)
        Hi @gsmetzer I've moved your topic since it's related to Cinema 4D API itself.
        I also added tags to your post and mark the topic as a question. Don't worry but the next time try to setup your topic correctly, see Q&A New Functionality and How to Post Questions.
        Regarding your issue, rs = op[c4d.ID_USERDATA,1] #get my rangeSlider performs a copy of the RangeData to the rs variable. So you have to assign it back at the end of your code op[c4d.ID_USERDATA,1] = rs
        • G Offline
          gsmetzer
          Thank You,
          How embarrassing I forgot to write back to the UserData. (I shouldn't code late at night) Solved.
