    Keyframe Selection Code from Cineversity
    r21python
    3 Posts 2 Posters 404 Views 1 Watching
    • B Offline
      bentraje
      I'm trying to use this keyframe selection code from Cineversity..
      I select an object but it prints nothing in the console. It also does not error out. You can see an illustration of the problem here:
      https://www.dropbox.com/s/idwazt6lxg11mcl/c4d146_key_frame_selection.mp4?dl=0
      Should I change something in the code to accommodate possible changes in the Python API?
        works fine for me. But the code is missing import statements and a call to main(). Also the indentation is all messed up when you copy the code from their homepage. I just mangled the code through an autopeper, added import and invoked main().
        On a side note: I am not sure if this is code you should learn from. This fine if you just want to get something done. For a learning site I find this unsuitable, but maybe I am to picky.
        def GetKeyframeSelection(op):
            if not op or not op.KeyframeSelectionContent():
                return None
            keySelection = []
            desc = op.GetDescription(c4d.DESCFLAGS_DESC_0)
            for bc, paramid, groupid in desc:
                # print paramid
                # Handle Vectors - seems desc iterator only does top level
                if paramid[0].dtype == c4d.DTYPE_VECTOR:
                    for i in xrange(c4d.VECTOR_X, c4d.VECTOR_Z+1):
                        did = c4d.DescID(
                            paramid[0], c4d.DescLevel(i, c4d.DTYPE_REAL, 0))
                        if op.FindKeyframeSelection(did):
                            keySelection.append(did)
                # Handle top level DescIDs
                elif op.FindKeyframeSelection(paramid):
                    keySelection.append(paramid)
            return keySelection
            keySelection = GetKeyframeSelection(op)
            if keySelection:
                print "*"*4, "Keyframe Select IDs", "*"*4
                print keySelection
        zipit
        • B Offline
          bentraje
          @zipit
          Thanks for the clarification.
          Yea, I guess so but just learning as much as I can.
          Thanks again!
