    Is there a way to change the GvNode Port Index
    Cinema 4D SDK
    c++ r21
    • J
      Jmelon
      i noticed drag port can change the ports order,but haven't find any message about how to resort the GvNode Port index in SDK, is this possible by code?
      hope your help.
      • S
        s_bach
        can you explain a little bit more what you are doing? What kind of plugin are you writing?
        • J
          Jmelon @s_bach
          @s_bach just a sudden thought when i use GvPort* GetInPort(Int32 index) go through all the InPorts. i attempt to change InPorts index but failed, is there a way to do that?
          • M
            There is actually no function for doing that. The only workaround is to delete/recreate everything by yourself.
            • J
              Jmelon @m_adam
              @m_adam disappointed 😥 😥 😥 , thank you for your answer.
              And if i create my own GvOperatorData, can i get the message when change Port Index by mouse Drag?
              • M
                m_adam @Jmelon
                @Jmelon I'm sorry there is no specific message sent to the GvOperatorData It's all handled in the UI.
