    Cloner with multi-instance
    c++r21
    4 Posts 3 Posters 824 Views 1 Watching
    • P Offline
      peterakos
      Hello.
      I want to support to fully support multi-instances in my render engine, but I find some difficulties with cloners.
      I transfer the cloner data into my engine by reading the Cache. The problem is that the multi instances that exist inside the cloner have the parameter INSTANCEOBJECT_MULTIPOSITIONINPUT empty.
      How can I get the multi instance positions from the cloner ?
      Thank you for your time !
      • fwilleke80F Offline
        fwilleke80
        You can get the array with matrices using this member function:
        const maxon::BaseArray<Matrix>* InstanceObject::GetInstanceMatrices() const
        Frank
        www.frankwilleke.de
          hello,
          I'm not sure if you are talking about a Mograph Cloner or an Instance with Instance Mode set to Multi-Instance.
          For a Cloner Object you can retrieve the matrices inside the MoData like this
                  BaseObject *mographObj = doc->GetActiveObject();
          	if (mographObj == nullptr)
          		return maxon::NullptrError(MAXON_SOURCE_LOCATION);
          	BaseTag *tag = mographObj->GetTag(ID_MOTAGDATA);
          	if (tag == nullptr)
          	// populate the GetMoDataMessage instance by sending a MSG_GET_MODATA
          	GetMoDataMessage modataMsg;
          	if (!tag->Message(MSG_GET_MODATA, &modataMsg))
          		return maxon::UnexpectedError(MAXON_SOURCE_LOCATION);
          	if (!modataMsg.modata)
          	// access the MoData from the returned GetMoDataMessage and check its validity
          	MoData *moData = modataMsg.modata;
          	if (!moData)
          	// retrieve the number of Matrix items as well as the array containing the matrix for each of them
          	maxon::Int32 matrixItemsCnt = moData->GetCount();
          	maxon::Matrix* itemsMtxArray = static_cast<maxon::Matrix*>(moData->GetArray(MODATA_MATRIX));
          If you are using An InstanceObject you can check our manual .
          As @fwilleke80 said you have GetInstanceMatrices or you can read the multi-instanceData (example in the manual)
          Manuel.
            hello,
            without further addition on your part, this thread will be considered as solved tomorrow.
            Manuel.
