    utils.ViewportSelect() Problem
    r19r20r21python
    5 Posts 2 Posters 1.3k Views 2 Watching
    • gheyretG Offline
      gheyret
      Hi! guys! Here's the problem with utils.ViewportSelect()
      This is my code:
      ViewportSelect = c4d.utils.ViewportSelect()
      frame = bd.GetFrame()
      left = frame["cl"]
      right = frame["cr"]
      top = frame["ct"]
      bottom = frame["cb"]
      width = right - left + 1
      height = bottom - top +1
      pick_obj = ViewportSelect.PickObject(bd, doc, mx, my, 0, c4d.VIEWPORT_PICK_FLAGS_0)
      print pick_obj
      ViewportSelect.Init(width, height, bd, pick_obj, c4d.Mpolyedgepoint, True, c4d.VIEWPORTSELECTFLAGS_IGNORE_HIDDEN_SEL)
      for obj in pick_obj:
              print obj
              nearest_poly = ViewportSelect.GetNearestPolygon(obj, mx, my, 0, False)
      Cinema 4D giving feedback: RuntimeError: Object is not initialized yet.
      How can i fix it?
      www.boghma.com
        you cannot use the ViewportSelect before you have initialised it. So you can only invoke PickObject() after you have invoked Init().
        zipit
        • gheyretG Offline
          gheyret
          Like this? But C4D giving feedback: UnboundLocalError: local variable 'pick_obj' referenced before assignment.
          www.boghma.com
            unless you have defined pick_obj somewhere else you cannot pass it to your Init() before you actually define it in the next line.
            zipit
            gheyretG 1 Reply Last reply Reply Quote 0
            • gheyretG Offline
              gheyret @ferdinand
              @zipit
              Thank you man ! I see how to fix it now!~~
              harry
              www.boghma.com
