    Moving a group of spline points
    pythonsdk
    3 Posts 2 Posters 558 Views 2 Watching
    • mfersaouiM Offline
      mfersaoui
      I want to moving group of spline points by just moving one another point as parent controller.
      In my example (see screenshot below), I want to control the Y position of all the point after the point 1by just moving the point 1 (using the point 1 like as a parent object)
          pline_object = op
          height = 800
          # set the points
          spline_object.SetPoint(0, c4d.Vector(0,0, 0))
          spline_object.SetPoint(1, c4d.Vector(0,height,0))
          obj_pnts = spline_object.GetAllPoints()
          for i in xrange(len(obj_pnts)):
              if i > 1 :
                  # What do I make on: obj_pnts[i].y
                  spline_object.SetPoint(i, c4d.Vector(obj_pnts[i].x, obj_pnts[i].y, obj_pnts[i].z))
      Thank you.
      mfersaouiM 1 Reply Last reply Reply Quote 0
        mfersaoui @mfersaoui
        I found the solution :
            pline_object = op
            height = 800
            # set the points
            #spline_object.SetPoint(1, c4d.Vector(0,height,0))
                if i > 0 :
                    interval = height - obj_pnts[1].y
                    spline_object.SetPoint(i, c4d.Vector(obj_pnts[i].x,obj_pnts[1].y+(obj_pnts[i].y-obj_pnts[1].y)+interval, obj_pnts[i].z))
          hello,
          happy you found your solution, and thanks for the feedback 🙂
