    Unusual Dynamic Inputs from GeDialog
    r20python
    3 Posts 2 Posters 429 Views 1 Watching
    • B Offline
      bentraje
      I am trying to create a dialog that list objects in the scene with specific parameters. However, it somehow skips some rows unexpectedly. You can see an illustration of the problem here:
      https://www.dropbox.com/s/hppgdpa3ghpsr9t/c4d135_unusual_dynamic_inputs.mp4?dl=0
      Is there a way around this?
      You can check the working code here. The glitch happens in the line for idx, object in enumerate(self.objectsList) block:
      import os
      from c4d import gui, plugins, bitmaps, utils, documents
      PLUGIN_ID   = 1811321
      class MyDialog(gui.GeDialog):
          def __init__(self):
              # Be sure that we have the object list before building the UI
              # as InitValues is called after CreateLayout()
              self.objectsList = []
              self.GetAllObjects()
              self.object_count = len(self.objectsList)
          def InitValues(self):
              # Use to Init and in Case of an Update needed.
              self.Update()
          def GetNextObject(self, op ):
              # use a non-recursive method to iterate the hierarchy
              # [URL-REMOVED]
              # allow to not hit the recursive stack limit.
              if not op:
                  return None
              if op.GetDown():
                  return op.GetDown()
              while not op.GetNext() and op.GetUp():
                  op = op.GetUp()
              return op.GetNext()
          def GetAllObjects(self):
              op = doc.GetFirstObject()
              while op:
                  self.objectsList.append(op)
                  op = self.GetNextObject(op)
          def Update(self): # NEW CODE
              if self.object_count == 0:
                  self.LayoutFlushGroup(1001)
                  self.AddStaticText(0, c4d.BFH_CENTER, name="There are no objects in the scene")
                  self.LayoutChanged(1001)
              if self.object_count > 0 :
                  self.AddStaticText(0, 1, name="Name")
                  self.AddStaticText(0, 0, name="Enable")
                  self.AddStaticText(0, 0, name="Xray")
                  self.AddSeparatorV(0)
                  for idx, object in enumerate(self.objectsList): # where the glitch happens
                      text_ID = (idx) * 1
                      enable_ID = (idx) * 2
                      xray_ID = (idx) * 3
                      self.AddEditText(text_ID, flags=c4d.BFH_LEFT, initw=200, editflags=c4d.EDITTEXT_HELPTEXT)
                      self.AddCheckbox(enable_ID, flags=c4d.BFH_LEFT, initw=20, inith=10, name="Enable")
                      self.AddCheckbox(xray_ID, flags=c4d.BFH_LEFT, initw=20, inith=10, name="Xray")
                      self.SetString(text_ID, value=object.GetName())
                      self.SetInt32(enable_ID, value=object[c4d.ID_BASEOBJECT_GENERATOR_FLAG])
                      self.SetInt32(xray_ID, value=object[c4d.ID_BASEOBJECT_XRAY])
          def CreateLayout(self):
              print "nombre d'objet ", self.object_count
              self.GroupBegin(id=1001, flags=c4d.BFH_FIT, cols=3, rows=20, title="Rigging")
              self.GroupEnd()
              self.Update()
          def Command(self, id, msg):
          def CoreMessage(self, id, msg):
              if id == c4d.EVMSG_CHANGE:
                  self.InitValues()
      class MyMenuPlugin(plugins.CommandData):
          dialog = None
          def Execute(self, doc):
              if self.dialog is None:
                  self.dialog = MyDialog()
              return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
          plugins.RegisterCommandPlugin(PLUGIN_ID, "test_dynamic_update",0, None, "test_dynamic_update", MyMenuPlugin())
      Thank you for looking at my problem.
        @bentraje said in Unusual Dynamic Inputs from GeDialog:
                   text_ID = (idx) * 1
                    xray_ID = (idx) * 3
        You actually overwrite the data yourself.
        idx at 0, so text_ID = 0, enable_ID = 0, xray_ID = 0
        idx at 1, so text_ID = 1, enable_ID = 2, xray_ID = 3
        idx at 2, so text_ID = 2, enable_ID = 4, xray_ID = 6
        idx at 3, so text_ID = 3, enable_ID = 6, xray_ID = 9
        etc...
        So please rethink your algorithm, the easier way is to have a base ID for all tree and add the current index like
        text_ID = 100000 + idx
        enable_ID = 200000 + idx
        xray_ID = 300000 + idx
        • B Offline
          bentraje
          @m_adam
          Thanks for the help. Works as expected.
          Have a great day ahead!
