    API questions
    3 Posts 2 Posters 865 Views 1 Watching
    • J Offline
      jesse
      is there a built in way to convert the render setting file tokens to what they are represent?
      also is there a way to save a .c4d file with out the file location window popping up using python?
        Hi @jesse first of all welcome in the plugincafe community.
        I would like to point you to a few rules for your next topics (I've set up this one correctly).
        • How to Post Questions, especially the tagging part and the correct category.
        • Q&A New Functionality.
        Now in regards to the first question, yes it's possible you should use c4d.modules.tokensystem.StringConvertTokensFilter or c4d.modules.tokensystem.FilenameConvertTokensFilter.
        A quick example:
            # Defines a path, with the $frame and $prj token
            path = r"/myprojects/topnotchproject/theimage_$frame_$prj.png"
            print(path)
            # Setups the RenderPathData
            rpd = {'_doc': doc, '_rData': doc.GetActiveRenderData(), '_rBc': doc.GetActiveRenderData().GetData(), '_frame': 1}
            # Excludes the project token to the "tokenization"
            exclude = ['prj']
            # Renders token to string
            finalFilename = c4d.modules.tokensystem.StringConvertTokensFilter(path, rpd, exclude)
            print(finalFilename)
            # Renders tokens to string and also change / to \
            finalFilename = c4d.modules.tokensystem.FilenameConvertTokensFilter(path, rpd, exclude)
        While it's in C++, it's still worth looking at the Token Manual.
        Then for the second question, you can save a .c4d file (or a document) by calling c4d.documents.SaveDocument, by default dialog are not allowed to pop up.
        If you have any questions, let me know.
        J 1 Reply Last reply Reply Quote 2
        • J Offline
          jesse @m_adam
          @m_adam thanks
          so using c4d.documents.SaveDocument the window is still showing up.. even with "SAVEDOCUMENTFLAGS_NONE" or "SAVEDOCUMENTFLAGS_AUTOSAVE"
          could it still be showing up because of an error in the file path its trying to save to or something like that?
