    Search Icon in Menubar
    3 Posts 2 Posters 602 Views 1 Watching
    • lasselauchL Offline
      lasselauch
      Hi everyone,
      is there a simple solution to add this search icon to the Dialogs Menubar..? (via Python)
      Lasse
        Hi @lasselauch sorry for the late reply was pretty busy these days.
        There is no built-in way and have to create a BitmapButtonCustomGui then use GeDialog.HideElement
        Find an example below:
        Copyright: MAXON Computer GmbH
        Author: Maxime Adam
        Description:
            - Creates an async Dialog with a top menu.
            - Defines an icon in the menu to toggle group visibility.
        Class/method highlighted:
            - c4d.gui.GeDialog
            - GeDialog.CreateLayout()
            - c4d.gui.BitmapButtonCustomGui
            - GeDialog.MenuFlushAll()
            - GeDialog.MenuAddString()
            - GeDialog.InitValues()
            - GeDialog.HideElement()
            - GeDialog.Command()
            - GeDialog.LayoutChanged()
        Compatible:
            - Win / Mac
            - R15, R16, R17, R18, R19, R20
        class MenuDlg(c4d.gui.GeDialog):
            ID_LEFT_MENU_FIRST_ITEM = 10000
            ID_RIGHT_MENU_SHOW_CONTENT = 10001
            ID_MAIN_GROUP = 10002
            ID_HIDDEN_GROUP = 10003
            displayContentButtonDlg = None
            toogleState = True
            def CreateLayout(self):
                This method is called automatically when Cinema 4D Create the Layout (display) of the Dialog.
                # Defines the title of the Dialog
                self.SetTitle("A Custom Dialog with a Top Menu")
                # Flushes all the already existing menu to create our one. The content will be on the left.
                self.MenuFlushAll()
                # Creates a Sub menu begin to inserts new menu entry
                self.MenuSubBegin("Left Menu")
                # Adds a string with a given ID, so it will trigger a call to Command once clicked
                self.MenuAddString(self.ID_LEFT_MENU_FIRST_ITEM, "Close")
                # Finalizes the Sub Menu
                self.MenuSubEnd()
                # Finalizes the menu
                self.MenuFinished()
                # Creates a Group in the Menu. The content will be on the right
                if self.GroupBeginInMenuLine():
                    # Creates a BitmapButtonCustomGui with the find icon
                    settings = c4d.BaseContainer()
                    settings[c4d.BITMAPBUTTON_BUTTON] = True
                    settings[c4d.BITMAPBUTTON_BORDER] = False
                    settings[c4d.BITMAPBUTTON_TOGGLE] = True
                    settings[c4d.BITMAPBUTTON_ICONID1] = c4d.RESOURCEIMAGE_SCENEBROWSER_FIND2
                    settings[c4d.BITMAPBUTTON_ICONID2] = c4d.RESOURCEIMAGE_SCENEBROWSER_FIND1
                    self.displayContentButtonDlg = self.AddCustomGui(self.ID_RIGHT_MENU_SHOW_CONTENT,
        c4d.CUSTOMGUI_BITMAPBUTTON, "",
        c4d.BFH_CENTER | c4d.BFV_CENTER, 0, 0, settings)
                self.GroupEnd()
                # Creates a group that will contain the content that will be hidden when the BitmapButton is pressed. It's
                # important to have a parent group to the group that needs to be hidden since you need to redraw this parent
                # group after the visibility definition.
                if self.GroupBegin(self.ID_MAIN_GROUP, c4d.BFH_LEFT | c4d.BFV_CENTER):
                    # The group that will be hidden
                    if self.GroupBegin(self.ID_HIDDEN_GROUP, c4d.BFH_LEFT | c4d.BFV_CENTER):
                        # Adds the content you want to toggle
                        self.AddStaticText(0, c4d.BFH_LEFT | c4d.BFV_CENTER, name="test")
                    self.GroupEnd()
                self.GroupEnd()
                # Adds two buttons, Ok and Cancel
                self.AddDlgGroup(c4d.DLG_OK | c4d.DLG_CANCEL)
            def InitValues(self):
                This method is called automatically after the GUI is initialized.
                # Defines the initial hidden state of the group according the the value stored.
                self.HideElement(self.ID_HIDDEN_GROUP, self.toogleState)
            def Command(self, id, msg):
                This method is called automatically when the user clicks on a gadget and/or changes its value
                this function will be called.
                It is also called when a string menu item is selected.
                :param id: The ID of the gadget that triggered the event.
                :param msg: The original message container
                :return: False if there was an error, otherwise True.
                # If the user click on the "Close" item of the menu
                if id == self.ID_LEFT_MENU_FIRST_ITEM:
                    self.Close()
                # If the user click on the bitmap button from the menu
                elif id == self.ID_RIGHT_MENU_SHOW_CONTENT:
                    # Updates the stored value of the toggle state
                    self.toogleState = not self.toogleState
                    # Hides the element
                    # Notifies that the content of the parent group of the group we just hide has changed and need to be redrawn
                    self.LayoutChanged(self.ID_MAIN_GROUP)
            # Quick hack since menu can only be displayed in an async dialog
            # Please don't do this on production, instead create a CommandData to store the GeDialog instance
            global diag
            # Creates an instance of the object MenuDlg
            diag = MenuDlg()
            # Opens the Dialog, Cinema 4D will then call CreateLayout, InitValues and so on...
            diag.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=-2, defaulth=-2)
          lasselauch
          Wow, thanks so much for this complete Example, Maxime..!!!
          Great work, really appreciated!
          Lasse
