    Dynamic Update on Plug-ins
    r20python
    5 Posts 3 Posters 790 Views 1 Watching
    • B Offline
      bentraje
      NOTE: Not talking about updating to new version but updating the execution of the plug-in.
      I have a test plug-in that prints out "There are no objects in the scene" or "There are # objects in the scene".
      It works as expected upon initial open of the plug-in but not through-out.
      You can see an illustration of the problem here:
      https://www.dropbox.com/s/6j0aqtvgg6o2vg6/c4d131_automatic_update-plug-in.mp4?dl=0
      Thank you for looking at my problem
      P.S. I need the LayoutFLushGroup and LayoutChanged in the code since I'm planning to list all objects and all their parameters.
      You can see the illustration code here:
      import os
      from c4d import gui, plugins, bitmaps, utils, documents
      PLUGIN_ID   = 1011321
      class MyDialog(gui.GeDialog):
          def get_all_objects(self, op):
            output = []
            while op:
                output.append(op)
                self.get_all_objects(op.GetDown())
                op = op.GetNext()
            return output
          def CreateLayout(self):
            self.object_count = len(self.get_all_objects(doc.GetFirstObject()))
            self.GroupBegin(id=1000, flags=c4d.BFH_FIT, cols=0, rows=4, title="Rigging")
            if self.object_count == 0:
              self.LayoutFlushGroup(1001)
              self.AddStaticText(0, c4d.BFH_CENTER, name="There are no objects in the scene")
              self.LayoutChanged(1001)
            if self.object_count > 0 :
              self.AddStaticText(0, c4d.BFH_CENTER, name="There are %s objects in the scene" %self.object_count)
            self.GroupEnd()
          def Command(self, id, msg):
      class MyMenuPlugin(plugins.CommandData):
          dialog = None
          def Execute(self, doc):
             if self.dialog is None:
                self.dialog = MyDialog()
             return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
          plugins.RegisterCommandPlugin(PLUGIN_ID, "BT Utilities",0, None, "Python Menu", MyMenuPlugin())
      • C4DSC Offline
        C4DS
        I haven't looked at your dropbox video, but from your explanation I seem to understand you will have to listen and react to message EVMSG_CHANGE. There is no other way to react to objects being added, or removed from the Object Manager.
        Obviously, the EVMSG_CHANGE will be called for every little change that occur in a scene, so you will probably need to filter out "false positives", if you don't want/need to update too frequently.
        • B Offline
          bentraje
          @C4DS
          Thanks for the response. I incorporated the EVMSG_CHANGE. It does not error out but it also does not work as expected (Behavior is still the same as before). Is there a way around this?
          You can check the revised code here:
          import os
          PLUGIN_ID   = 1011321
                output = []
                while op:
                    output.append(op)
                    op = op.GetNext()
                return output
              def Update(self): # NEW CODE
                self.GroupBegin(id=1001, flags=c4d.BFH_FIT, cols=0, rows=4, title="Rigging")
                self.GroupEnd()
                self.Update() # NEW CODE
              def CoreMessage(self, id, msg):
                if id == c4d.EVMSG_CHANGE: # NEW CODE
                  self.Update()
              dialog = None
            hello @bentraje,
            In your code get_all_objects was not called and not updating object_count
            I've changed your code a bit. I've used a non-recursive hierarchy iteration found in our blog[URL-REMOVED] so you don't hit the stack limit in case of a big hierarchy.
            InitValues is called after CreateLayout so that's why I've used __init__ in the first place to init my values.
            In my code i'm using self.objectsList to store the object list. It's just for this example, GeDialog is not the best place to store data.
            import os
            PLUGIN_ID   = 1011321
                def __init__(self):
                    # Be sure that we have the object list before building the UI
                    # as InitValues is called after CreateLayout()
                    self.objectsList = []
                    self.GetAllObjects()
                    self.object_count = len(self.objectsList)
                def InitValues(self):
                    # Use to Init and in Case of an Update needed.
                    self.Update()
                def GetNextObject(self, op ):
                    # use a non-recursive method to iterate the hierarchy
                    # [URL-REMOVED]
                    # allow to not hit the recursive stack limit.
                    if not op:
                        return None
                    if op.GetDown():
                        return op.GetDown()
                    while not op.GetNext() and op.GetUp():
                        op = op.GetUp()
                    return op.GetNext()
                def GetAllObjects(self):
                    op = doc.GetFirstObject()
                    while op:
                        self.objectsList.append(op)
                        op = self.GetNextObject(op)
                    print "nombre d'objet ", self.object_count
                    self.GroupEnd()
                        self.InitValues()
                dialog = None
            • B Offline
              bentraje
              Hi @m_magalhaes
              Thanks for the response and clarification specially with the
              def __init___ and def InitValuesthat was news to me.
              The plug-in works as expected. Have a great day ahead!
