    GeGetModata inside Python Generator returns none
    r20python
    3 Posts 2 Posters 944 Views 1 Watching
    • P Offline
      pyr
      i use a clone with a null object to generate me some point lists for further processing. unfortunally i'm not able to get the modata from this cloner.
      see setup for details:
      cloneNone.c4d
        hello,
        this is because the modata are store in a tag that is not created yet.
        a "workaround" is to create it in a "temporary document" and ExecutePasses() on it.
        So the cloner will create the hidden tag and you will be able to retrieve the MoData
        def CreateClonerAndFun(base, rad):
            Creates the cloner, clone the base.
            Creates the effector
            return the parent and the cloner.
            parent  = c4d.BaseObject(c4d.Onull)
            base = base.GetClone()
            base.InsertUnderLast(parent)
            cloner  = c4d.BaseObject(1018544)
            cloner.InsertUnder(parent)
            p = c4d.BaseObject(c4d.Onull)
            p[c4d.NULLOBJECT_DISPLAY] = 2
            p[c4d.NULLOBJECT_RADIUS] = rad
            p.InsertUnder(cloner)
            pushEffector = c4d.BaseObject(440000219)
            pushEffector[c4d.MGPUSHAPARTEFFECTOR_MODE] = 0
            pushEffector[c4d.MGPUSHAPARTEFFECTOR_RADIUS] = rad
            pushEffector.InsertUnderLast(parent)
            ie = c4d.InExcludeData()
            ie.InsertObject(pushEffector,15)
            cloner[c4d.ID_MG_MOTIONGENERATOR_MODE] = 0
            cloner[c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST] = ie
            cloner[c4d.MG_OBJECT_LINK] = base
            cloner[c4d.MG_POLY_MODE_] = 0
            return parent, cloner
            # Checks if we got a child
            child = op.GetDown()
            if child is None:
                raise ValueError("no child on this generator")
            # using a function to avoid double code
            parent, cloner = CreateClonerAndFun(child, 10)
            # Creates a new Document
            newDoc = c4d.documents.BaseDocument()
            # Inserts the object in the new document
            newDoc.InsertObject(parent)
            # ExecutePasses on the document
            if not newDoc.ExecutePasses(None,True,True,True, c4d.BUILDFLAGS_NONE):
                raise ValueError("erro while updating the document")
            # Retrieves the modata from the object
            md = c4d.modules.mograph.GeGetMoData(cloner)
            print md
            # Re-create the cloner but this time to return the parent.
            return CreateClonerAndFun(child, 10)[0]
        • P Offline
          pyr
          to be honest - i don't know where my fault was. Unhappily i didn't commit the not working version. In my plugin i
          already used a virtual doc for some other calculations. thank you!
          vd.ExecutePasses(c4d.threading.GeGetCurrentThread(), True, True, True, c4d.BUILDFLAGS_NONE)
          md = c4d.modules.mograph.GeGetMoData(matrix)
          for m in md.GetArray(c4d.MODATA_MATRIX): rdPoints.append(m.off)
          works like a sharm.
