    Matrix/HPB to XYZ and vice versa
    pythonr20
    7 Posts 2 Posters 2.4k Views 1 Watching
    • S Offline
      sheilan
      I've got some models in two different softwares, when one is using XYZ rotation and the other (cinema 4d) uses HPB/Matrix.
      I couldn't find a way to get my model's XYZ via Python (only Matrix), so I'm looking to see how can I translate rotation matrix or HPB to XYZ and vice versa.
      Thanks in advance,
      Sheilan.
        hello,
        what come to my mind is those functions MatrixToHPB and HPBToMatrix
        Or maybe i didn't understood your question.
        S 1 Reply Last reply Reply Quote 1
        • S Offline
          sheilan @Manuel
          @m_magalhaes Hello,
          You misunderstood. I'm able to get Matrix & HBP but I need XYZ. I'm looking for either MatrixToXYZ or HPBToXYZ (preferably the first one).
          Sheilan.
            hello,
            there's different flags you can use in that function, all values are differents.
                m = op.GetMg()
                print c4d.utils.MatrixToHPB(m, order=c4d.ROTATIONORDER_DEFAULT)
                print c4d.utils.MatrixToHPB(m, order=c4d.ROTATIONORDER_XYZGLOBAL)
                print c4d.utils.MatrixToHPB(m, order=c4d.ROTATIONORDER_XYZLOCAL)
            what software are you using ? What are the types of XYZ (vector floats) ?
            S 1 Reply Last reply Reply Quote 0
            • S Offline
              sheilan @Manuel
              @m_magalhaes
              I tried creating a cube and setting it's HBP manually.
              HBP - 47º 0º 0º
              XYZ - 0º 47º 0º
              and the result is
              Vector(0.82, 0, 0)
              Vector(0, 0.82, 0)
              Vector(0, 0.82, 0)
              What I need is a result of Vector float that shows (0.0, 47.0, 0,0) (XYZ) as a result.
                Angles are always store in radian internally. 47° is the same as 0.820304748437 radians.
                you can convert using this function DegToRad
                I think that's what you have with the flag ROTATIONORDER_XYZGLOBAL
                    m = op.GetMg()
                    # convert the matrix to XYZ
                    xyz =  c4d.utils.MatrixToHPB(m, order=c4d.ROTATIONORDER_XYZGLOBAL)
                    # convert from radian to deg
                    for i in xrange(3):
                        xyz[i] = c4d.utils.RadToDeg(xyz[i])
                    print xyz
                • S Offline
                  sheilan @Manuel
                  @m_magalhaes said in Matrix/HPB to XYZ and vice versa:
                  for i in xrange(3):
                  print xyz
                  Works perfectly. Thanks!
