    Simulating a Scrub in the Timeline?
    r20python
    4 Posts 3 Posters 1.1k Views 2 Watching
    • B Offline
      bentraje
      I made a rig, and for some reason, it does not work well unless I scrub the timeline. It's as if the timeline gives an update to the scene. You can see an illustration of the problem here:
      https://www.dropbox.com/s/anlueipqy6t6rhw/c4d125_simulate_moving_timeline.mp4?dl=0
      I'm not sure about this but I guess the term to do this redraw, correct me if I'm wrong.
      I checked the documentation but the redraw() method is only available under c4d.gui module.
      Is there a way to simulate a scrub in the timeline or redraw on a document/scene level?
      Thank you for looking at my problem.
        mp5gosu
        You may want to try ExecutePasses() - that command will animate the current frame of the document and therefore works like scrubbing the timeline.
        • B Offline
          bentraje
          @mp5gosu
          Not sure about the whole mechanics of the command but it works.
          Here is the code I used:
          doc.ExecutePasses(None, True, True,True,c4d.BUILDFLAGS_0)
          • ManuelM Online
            hi @bentraje ,
            Just to confirm @mp5gosu answer.
            We can also point you to BaseDocument manual where you have some information about ExecutePasses
