    ProjectTool & visual studio: /DELAYLOAD
    8 Posts 2 Posters 1.9k Views 1 Watching
    • F Offline
      FilipM
      Hi!
      With the project tool, is it possible to specify visual studio-specific options beyond the options outlined here in the docs: https://developers.maxon.net/docs/cpp/2023_2/page_maxonapi_projecttool.html#page_maxonapi_projecttool_definition_win ?
      Specifically, I would like to set the /DELAYLOAD linker option in my project from the projecttool. Is this possible?
      /Filip
        hello,
        First, for your next threads, please help us keeping things organised and clean. I know it's not your priority but it really simplify our work here.
        • Q&A New Functionality.
        I've marked this thread as a question so when you considered it as solved, please change the state 🙂
        About you question :
        In the page you linked (i'm not blaming you i didn't saw it neither) there's the option AdditionalLinkOptions
        something like this should work :
        AdditionalLinkOptions=/DELAYLOAD:"mydll.dll"
        It will be added to your linker properties "Configuration Properties-> Linker ->All Options->Additional Options"
        Let me know if this solve your issue.
        • F Offline
          FilipM
          Thanks, I'll try that!
          Regarding the "Ask as a question", have you considered making this the deafult when creating new threads? I would assume most new threads are indeed questions, and it's easy to forget checking this option.
          /Filip
          • F Offline
            FilipM
            Actually, this does not seem to solve my problem. The option gets added under
            just as you said, but I would need to modify
            "Configuration Properties-> Linker ->All Options->Delay Loaded DLLs".
            Is this possible from the project tool? This is for a public open source software, so I would really like to make the build process as streamlined as possible to aid external developers. Therefore, I would like to avoid manually changing the projects generated by the projecttool.
            /Filip
              hello,
              I've asked the devs, i'll be back as soon as I have information.
                hello,
                The command appears in Configuration Properties->linker->Command Line (the bottom box "Additional Options").
                (I wonder why I didn't saw it xD : please don't answer that question ^^ )
                It should be taken into account. Do you see any difference between adding your command there or in "Configuration Properties-> Linker ->All Options->Delay Loaded DLLs". ?
                on windows
                like so
                AdditionalLinkOptions=%(AdditionalOptions) /DELAYLOAD:"mydll.dll"
                for OSX you can use
                OTHER_LDFLAGS
                like so
                OTHER_LDFLAGS=-lazy_library;../pathToYourDylib
                some warning on OSX :
                Note however, that this delayed loading is deprecated in Xcode 11 on macOS 10.15 (and currently doesn't work anymore).
                • F Offline
                  FilipM
                  I will check this again. I am marking this as solved for now.
                  /Filip
                    hello,
                    if you can give us feedback that would be awesome.
