    Mograph Camera Shader from Python
    3 Posts 2 Posters 740 Views 1 Watching
    • F Offline
      fasteffect
      I'm trying to write a script to add the mograph camera shader to the luminance channel of a material, and then set the Camera target. I can insert other shaders, but I cannot locate in the documentation the correct way to instantiate that shader, nor how to modify the property of a shader once added to the material.
        hello ,
        here's an example on how to create a camera shader and set the link of the camera.
        Be aware you need to create the shader using it's ID so it could be changed in the future.
        I've used a script from @m_adam as a base and just added the camera shader stuff. You can thanks him a lot ^^
        from c4d import gui
            # Gets the active object
            if op is None:
                raise ValueError("op is none, please select one object.")
            # Retrieves the BaseDraw of Render View
            bd = doc.GetRenderBaseDraw()
            if bd is None:
                raise ValueError("no BaseDraw found")
            # Retrieves the scene camera
            cam = bd.GetSceneCamera(doc)
            if cam is None:
                raise ValueError("there's no camera")
            # Creates a default Cinema 4D Material, the created material only exist in the memory
            mat = c4d.BaseMaterial(c4d.Mmaterial)
            if mat is None:
                raise RuntimeError("Failed to creates a new BaseMaterial.")
            # Inserts the material in the active document
            doc.InsertMaterial(mat)
            # Creates the Camera Shader
            #be aware you have to use the ID here but it can changed in future release
            sha = c4d.BaseList2D(440000050)
            if sha is None:
                raise RuntimeError("Failed to creates a bitmap shader.")
            # Defines the camera link inside the shader
            sha[c4d.MGCAMERASHADER_LINK] = cam
            # Inserts the shader into the material
            mat[c4d.MATERIAL_COLOR_SHADER] = sha
            mat.InsertShader(sha)
            # Checks if there is already a texture tag on the active object, if not creates it
            textureTag = op.GetTag(c4d.Ttexture)
            if not textureTag:
                textureTag = op.MakeTag(c4d.Ttexture)
            # If the texture tag is not available at this point, something went wrong
            if textureTag is None:
                raise RuntimeError("Failed to retrieves the texture tag.")
            # Links the newly created material from the textureTag Material link parameter
            textureTag[c4d.TEXTURETAG_MATERIAL] = mat
            # Changes the texture tag projection to UVW
            textureTag[c4d.TEXTURETAG_PROJECTION] = c4d.TEXTURETAG_PROJECTION_UVW
            # Informs Cinema 4D something changed in the scene
        # Execute main()
        • F Offline
          fasteffect
          Thanks that worked perfectly. I thank you both!
