    Unable to Modify the Input Port of the Math Node
    Cinema 4D SDK
    r20 python
    • B
      bentraje
      I'm trying to create a math node and modify its corresponding Input[2]. However, it gives me an error TypeError: __setitem__ got unexpected type 'float' I tried with an integer but it also gives me an error.
      Is there a way around this?
      Thank you for looking at the problem.
      You can see the code here:
      # Main function
          cube = c4d.BaseObject(c4d.Ocube)
          doc.InsertObject(cube)
          expresso = cube.MakeTag((c4d.Texpresso))
          nodemaster = expresso.GetNodeMaster()
          math_node = nodemaster.CreateNode(nodemaster.GetRoot(), c4d.ID_OPERATOR_MATH, None, x=0, y=0)
          # This line works
          math_node[c4d.GV_MATH_FUNCTION_ID] = 2
          # This line does not work. The '[2000,1001]' was retrieved by dragging the Input[2] to the console.
          math_node[2000,1001] = -1.0
      # Execute main()
      • S
        s_bach
        the "input" parameters are dynamically created parameters. So it appears they need a little bit more love.
        It seems to work using the fully qualified DescID and SetParamter().
        subContainerID = c4d.DescLevel(2000, c4d.DTYPE_SUBCONTAINER, c4d.ID_OPERATOR_MATH)
        inputID = c4d.DescLevel(1001, c4d.DTYPE_REAL, c4d.ID_OPERATOR_MATH);
        paramID = c4d.DescID(subContainerID, inputID)
        math_node.SetParameter(paramID, 99.9, c4d.DESCFLAGS_SET_0)
        • B
          bentraje
          RE: appears they need a little bit more love.
          Thanks for the clarification. The code works as expected!
