    Get active object after random value
    Cinema 4D SDK
    python r19
    1.3k
    • W
      Wusiki
      Hello everyone.
      There are a few classes.
      One for choosing an object in the CycleList.
      Two for choosing a random object via change c4d.userdata value
      One works fine. But when I choose a random object I need to click on the viewport to update showing object. How to update viewport without clicking?
      I also have tried on the random class:
                  c4d.CallCommand(12147, 12147)
                  c4d.DrawViews( c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_REDUCTION|c4d.DA_STATICBREAK )
      It doesn't work.
      Object class:
       if (config['hideState'] == True): #hide selected object
                  for indexObjectHide in range (0, limit): #loop for geting all objects
                      if (indexObjectHide == self.userdataGroup[c4d.ID_USERDATA,userDataId]): #which object is selected
                          self.parentObject.GetChildren()[indexObjectHide].SetEditorMode(2)
                          self.parentObject.GetChildren()[indexObjectHide].SetRenderMode(2)
                          self.parentObject.GetChildren()[indexObjectHide].SetEditorMode(1)
                          self.parentObject.GetChildren()[indexObjectHide].SetRenderMode(1)
      Random class:
      if (self.userdataGroup[c4d.ID_USERDATA,userDataId] == True): #If random button clicked
                  SubLists = [] #
                  for ListIndex in range (0,len(config['Random id'])):#config['Random id'] is var where I can point userdata ids ehich will be randomed
                      SubLists.append([config['Random id'][ListIndex]])
                  indexList = []
                  for indexEl in range (0,len(SubLists)): #Loop for each id
                      for id, bc in self.userdataGroup.GetUserDataContainer():
                          cycleBC = bc.GetContainer(c4d.DESC_CYCLE)
                          if (id == c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER,0), c4d.DescLevel(SubLists[indexEl][0]))):
                              for element in cycleBC: # get userdata data
                                  if (len(indexList) == indexEl):
                                      indexList.append([element[0]])
                                      indexList[indexEl].append(element[0])
                      self.userdataGroup[c4d.ID_USERDATA,SubLists[indexEl][0]] = randint(0,len(indexList[indexEl]) - 1) #Change userdata values
                  self.userdataGroup[c4d.ID_USERDATA,userDataId] = False
      You can see full code in the attached c4d file. Pls help me
      For better understanding what I want, watch the video:
      Experieces.c4d
      Seems I've understood why I get the issue. I put random class before object class and it works 'cause in this code, I get an active object before getting random value. But it is doesn't correct in point of view of the code. It's hierarhy disturbing. Ways to generate active object after generating random?
      • S
        s_bach
        Hello and welcome,
        please use the Q&A system to mark your post as a question.
        Also, please use tags to inform us about which version of Cinema you are using.
        What do you mean with "hierarhy disturbing"? What do you mean with "generate active object after generating random"?
        Why is your user interface on the "Interface" null object and not the Python Tag itself? If your UI would be on the Python Tag, you could implement the tag's message() function to handle such user events properly.
        def message(id, data):
            if id == c4d.MSG_DESCRIPTION_COMMAND:
                buttonID = data['id']
                # check for user data
                if buttonID[0].id == c4d.ID_USERDATA:
                    # ceck button ID
                    if buttonID[1].id == 1:
                        print("button pressed")
        • W
          Wusiki
          @s_bach said in Get active object after random value:
          And...Done.
          "Hierarhy disturbing".
          Simply put, there is first func (where there are object details) and there is the second func which generate a random number, but data of active object stores in the first func. Need to execute the second func before first to make it works. But it doesn't right cause' it disturbs actions timeline. Right way is: First display object to the viewport, then generate random nimber after pressing button. But this code requires to run second func before first one.
          I think attached video link better speaks for me.
          Thanks. Need to try.
          • W
            Wusiki
            I get the same issue. The script gives only previous data (randint limit). I know why, but I don't know how to get an active data.
                    randomButtons = [5] #Random  buttons Ids
                    SubList = [] #container storing id's values to have to changing
                    SubList = randomId_new(SubList,[3,4])#filling the container
                    if buttonID[0].id == c4d.ID_USERDATA:#check for user data
                        for RandomButtonId in range (0,len(randomButtons)):#loop for each button
                            if buttonID[1].id == randomButtons[RandomButtonId]:#check button ID
                                for SublistId in range (0,len(SubList[RandomButtonId])):
                                    RandomLimit = 0 #limit for randint
                                    for id, bc in op.GetUserDataContainer():
                                        if (id == c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA, c4d.DTYPE_SUBCONTAINER,0), c4d.DescLevel(SubList[RandomButtonId][SublistId]))): #check id
                                            for element in cycleBC: #define len of cycleList
                                                RandomLimit += 1
                                    op[c4d.ID_USERDATA,SubList[RandomButtonId][SublistId]] = randint(0,RandomLimit - 1) #generate random value
                                    print(str(SubList[RandomButtonId][SublistId]) + ': ' + str(RandomLimit)) #checking to console
            You can see what I want via video
            • ManuelM
              hello,
              Is it possible to have the last version of your file so i have a chance to follow you and try to help you.
              • W
                Wusiki
                @m_magalhaes said in Get active object after random value:
                hello,
                Sure. Thanks in advance. I also commented on my code to better to understand.
                Experieces_old.c4d
                • ManuelM
                  hello,
                  You create your UI dynamically but still use it to retrieves data. You should simply separate both.
                  The problem here is that Message() is called before Main() (nothing you can changed)
                  In the Message() function you can check the id == MSG_DESCRIPTION_POSTSETPARAMETER, you can retrieves the descid in the data attached.
                  By checking the descid you can update only if the cycles are changed. (not the button)
                  Your Main() can be "empty". I picked everything that was in Main() and copy/paste in LaunchUpdate()
                  You should split that function in several parts.
                  In the random function I can now call LaunchUpdate() to update the UI and use it to retrieves the data. (but as I said you should separate both)
                  This now works but LaunchUpdate() is executed too much times. It would need more work to split that function in several parts.
                  This look more like a design issue than a Cinema4D issue.
                  Let me know if i'm not clear.
                  from c4d import gui
                  from c4d import documents
                  import random
                  from random import randint
                  class bcSettings():
                      def Group(self,basecontainerVar,groupContainerVar,columns=1,parentGroupState=False,parentGroupId=0):
                          return {'Base container': basecontainerVar, 'Group container': groupContainerVar,'Columns': columns,'Subgroup': parentGroupState,'Parent group id': parentGroupId}
                      def CycleObj(self,basecontainerVar,groupContainerVar,parentGroupId=0,hide=True):
                          return {'Base container': basecontainerVar, 'Group container': groupContainerVar,'Parent group id': parentGroupId,'hideState': hide}
                      def CycleTex(self,basecontainerVar,groupContainerVar,effect,shader,parentGroupId=0):
                          return {'Base container': basecontainerVar, 'Group container': groupContainerVar,'effect': effect,'shader': shader,'Parent group id': parentGroupId}
                      def RandomButton (self,basecontainerVar,groupContainerVar,parentGroupId=0):
                          return {'Base container': basecontainerVar, 'Group container': groupContainerVar,'Parent group id': parentGroupId}
                  def BaseContainerVariable(index,typeName): #it's list func for checking and adding to list a new varaibale instead use one unique variable
                      if (len(index) == 0):
                          index.append(typeName + str(1))
                          index.append(typeName + str(len(index) + 1))
                      return index
                  class base_controllers(object):
                      def __init__(self,userdataGroup,parentObject=None):
                          self.userdataGroup = userdataGroup
                          self.parentObject = parentObject
                      def Group(self,config,title,userDataId):
                          BaseContainerVariable(config['Base container'],'BaseContainerId')
                          CountCheckingBC = 0
                          #check if list is null and add new varabe to list
                          if (len(config['Base container']) > 0):
                              CountCheckingBC = len(config['Base container']) - 1
                              config['Base container'][CountCheckingBC] = title + 'BaseContainer'
                              config['Base container'][CountCheckingBC] = c4d.GetCustomDatatypeDefault(c4d.DTYPE_GROUP)
                              config['Base container'][0] = title + 'BaseContainer'
                              config['Base container'][0] = c4d.GetCustomDatatypeDefault(c4d.DTYPE_GROUP)
                          #continue creating userdata
                          config['Base container'][CountCheckingBC].SetString(c4d.DESC_NAME, title)
                          config['Base container'][CountCheckingBC].SetString(c4d.DESC_SHORT_NAME, title)
                          config['Base container'][CountCheckingBC].SetInt32(c4d.DESC_COLUMNS, config['Columns'])
                          if (config['Subgroup'] == True and config['Parent group id'] > 0 ): #check whether userdata should have a parent group
                              config['Base container'][CountCheckingBC].SetData(c4d.DESC_PARENTGROUP, c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA), c4d.DescLevel(config['Parent group id'], c4d.DTYPE_GROUP, 0)))
                          BaseContainerVariable(config['Group container'],'GroupContainerId')
                          CountCheckingCont = 0
                          if (len(config['Group container']) > 0):
                              CountCheckingCont = len(config['Group container']) - 1
                          config['Group container'][CountCheckingCont] = c4d.BaseContainer()
                          config['Base container'][CountCheckingBC].SetContainer(c4d.DESC_CYCLE, config['Group container'][CountCheckingCont])
                          self.userdataGroup.SetUserDataContainer([c4d.ID_USERDATA, userDataId], config['Base container'][CountCheckingBC])
                      def CycleObj(self,config,title,userDataId):
                          CountCheckingBC = 0
                              config['Base container'][CountCheckingBC] = c4d.GetCustomDatatypeDefault(c4d.DTYPE_LONG)
                              config['Base container'][0] = c4d.GetCustomDatatypeDefault(c4d.DTYPE_LONG)
                          limit = len(self.parentObject.GetChildren())
                          config['Base container'][CountCheckingBC].SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_CYCLE)
                          config['Base container'][CountCheckingBC].SetInt32(c4d.DESC_MIN, 0)
                          config['Base container'][CountCheckingBC].SetInt32(c4d.DESC_MAX, limit-1)
                          for indexLoop in range(0, limit):#filling userdata container with object names
                              config['Group container'][CountCheckingCont].SetString(indexLoop, self.parentObject.GetChildren()[indexLoop].GetName())
                          if (config['hideState'] == True): #hide all objects besides chosen
                      def CycleTex(self,config,title,userDataId):
                          layer_list = []
                          temp_list_var = config['shader'].GetFirstLayer()
                          layer_list.append(temp_list_var)
                          while temp_list_var:# get layers
                              if temp_list_var.GetNext() is not None:
                                  layer_list.append(temp_list_var.GetNext())
                                  temp_list_var = temp_list_var.GetNext()
                                  break
                          count_texture = len(layer_list)
                          CountCheckingBC = 0
                          config['Base container'][CountCheckingBC].SetInt32(c4d.DESC_MAX, count_texture-1)
                          if (config['effect'] == 'hide'):
                              for indexLoop in range(0, len(layer_list)):
                                  config['Group container'][CountCheckingCont].SetString(indexLoop, "Texture " + str(indexLoop + 1))
                              active_texture = self.userdataGroup[c4d.ID_USERDATA,userDataId]
                              if (active_texture >= count_texture):
                                  self.userdataGroup[c4d.ID_USERDATA,userDataId] = count_texture - 1
                              for index_active_texture in range(0,count_texture):
                                  if (index_active_texture == active_texture):
                                      layer_list[index_active_texture].SetParameter(c4d.LAYER_S_PARAM_ALL_ACTIVE, True)
                                      layer_list[index_active_texture].SetParameter(c4d.LAYER_S_PARAM_ALL_ACTIVE, False)
                          config['shader'].Message(c4d.MSG_CHANGE)
                      def RandomButton(self,config,title,userDataId):
                          CountCheckingBC = 0
                              config['Base container'][CountCheckingBC] = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BUTTON)
                              config['Base container'][0] = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BUTTON)
                          config['Base container'][CountCheckingBC].SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_BUTTON)
                      pass
                  def LaunchUpdate():
                      Interface = op.GetObject()
                      Objects = Interface.GetDown()
                      indexBc = []
                      groupBc = []
                      InterfaceGroup = bcSettings().Group(indexBc,groupBc)
                      base_controllers(op,Objects).Group(InterfaceGroup,'Interface',1)
                      ObjectsGroup = bcSettings().Group(indexBc,groupBc,3,True,1)
                      base_controllers(op,Objects).Group(ObjectsGroup,'Objects',2)
                      ObjectsCycle = bcSettings().CycleObj(indexBc,groupBc,2,True)
                      base_controllers(op,Objects).CycleObj(ObjectsCycle,'Object',3)
                      active_Ttag = Objects.GetChildren()[op[c4d.ID_USERDATA,3]].GetFirstTag()
                      active_Ttag = active_Ttag.GetNext()
                      active_mat = active_Ttag.GetMaterial()
                      if active_mat is None:
                      shader = active_mat[c4d.MATERIAL_COLOR_SHADER]
                      if shader is None:
                      TextureCycle = bcSettings().CycleTex(indexBc,groupBc,'hide',shader,2)
                      base_controllers(op,Objects).CycleTex(TextureCycle,'Texture',4)
                      ObjectRandomButton = bcSettings().RandomButton(indexBc,groupBc,2)
                      base_controllers(op,Objects).RandomButton(ObjectRandomButton,'Random',5)
                  def randomId_new(index,data):
                      index.append(data)
                      return index
                      if id == c4d.MSG_DESCRIPTION_POSTSETPARAMETER:
                          print data['descid']
                          LaunchUpdate()
                                          LaunchUpdate() # we can launch an update of the ui
                                                      RandomLimit += 1
                  • W
                    Wusiki
                    Hello.
                    Thank you so much. I've understood. Yea, it works. I'd break my mind to understand it by myself. So, then I gonna optimize drawcalls (don't know how to call it another) of LaunchUpdate() func
