    Lock / unlock plugin from Plugins menu
    8 Posts 3 Posters 1.2k Views 1 Watching
    • mfersaouiM Offline
      mfersaoui
      Is it possible to lock a plugin in the Plugins menu using python. like image below:
      I want to lock some of commands of my plugin depending on the selected object
      Thanks.
      • CairynC Offline
        Cairyn
        Override CommandData.GetState(doc) or ToolData.GetState(doc) to return a combination of
        CMD_ENABLED (enabled)
        CMD_VALUE (checked)
        or neither.
        mfersaouiM 1 Reply Last reply Reply Quote 0
          mfersaoui @Cairyn
          @Cairyn
          Thank you Cairyn,
          I had arrived at the result below :
          class MyCommand(c4d.plugins.CommandData):
              def __init__ (self):
                  self.isActive = False
              def Execute(self, doc):
              def GetState(self, doc):
                      if (self.isActive):
                          return c4d.CMD_ENABLED
                          return c4d.CMD_VALUE
          Now I'm searching , how to swap from disabled to enabled depending on the type of the selected object in Object Manager.
            mfersaoui @mfersaoui
            @mfersaoui
            I found this solution:
                    op = doc.GetActiveObject()
                    if op is not None and op.GetType() == OBJECT_ID:
                    else :
                        return False
              Hi @mfersaoui while True, False is supported it's better to return the correct value from the symbols (CMD_ENABLE) since in any case your bool will be converted to an Int and in the future value may change while symbols will remain the same.
              Moreover in R20 GetState is also available for script in the Script Manager.
                mfersaoui @m_adam
                @m_adam
                Thank you Maxime, I had used the (return False) because this give a different result visual of the icon.
                preview:
                Result (1) gived when use : return c4d.CMD_VALUE
                Result (2) gived when use : return False
                • CairynC Offline
                  Cairyn @mfersaoui
                  @mfersaoui You misunderstand the return value.
                  This is not a single true/false flag, but a set of flags. As I mentioned, CMD_ENABLED stands for the enabling of the command (greyed out if not set), and CMD_VALUE stands for the checked state (in case of icons, the background changes, as you saw in your test). These two flags are not mutually exclusive but can be used together! (use or to join).
                  The actual value to use if you want neither flag set is simply 0. False works in this case because the numeric equivalent of false is 0.
                  from c4d import gui
                  def state():
                      if op is not None:
                          if op.GetType() == c4d.Ocube :
                              return c4d.CMD_ENABLED | c4d.CMD_VALUE
                          elif op.GetType() == c4d.Ocylinder :
                          else :
                      return 0
                  # Main function
                      print "Triggered!"
                  # Execute main()
                  If you watch the above script as icon in a toolbar, you will see all four state combinations depending on what primitive you select. If nothing is selected, the icon is grayed out. If you select a cylinder, the icon is still grayed out and unselectable but the background changes to make clear it's checked. A cube will show both the checked and active states, and some other object will show only the active state.
                  To be fair, the standard default script in R20 mentions False explicitly though.
                  mfersaouiM 1 Reply Last reply Reply Quote 1
                    mfersaoui @Cairyn
                    @Cairyn Thank you for your detailed reply.
