    DrawMultipleHUDText issue
    9 Posts 2 Posters 2.1k Views 2 Watching
    • merkvilsonM Offline
      merkvilson
      Hello PluginCafe! 🙂
      I'm using Draw() method if TagData plugin for displaying multiple text values but I can't figure out, how the DrawMultipleHUDText works.
      Let's assume I have a list of strings
      abc = [ "Hello", "World", ]
      And a list of vectors (Usually I'm importing c4d.Vector as v)
      xyz = [v(0,100,0), v(0,200,0)]
      How should I pass them into DrawMultipleHUDText?
      I tried this method and it does not work.
          def Draw(self, tag, op, bd, bh):
              abc = ["Hello", "World"]
              xyz = [v(0, 100, 0), v(0, 200, 0)]
              values = {'_txt': abc, "_position": xyz}
              bd.DrawMultipleHUDText(values)
              return c4d.DRAWRESULT_OK
        merkvilson
        I want to display these values on top of other viewport elements.
          merkvilson
          Seems like I figured this out but it's kinda complicated.
                  values0 = [{'_txt': "Hello", "_position": v(100,100,0)},{'_txt': "World", "_position": v(200,200,0)}]
                  bd.DrawMultipleHUDText(values0)
            merkvilson
            The method above causes shading problems which can be solved by enabling depth option. bd.SetDepth(True)
            But it's still displayed on the background. Is it possible to bring it to the front?
              hello,
              I can resume your question to "Drawing something in front of everything"
              It's possible in a SCENEHOOK (witch is not supported in python).
              did you try to change the BaseDraw matrix ?
              I can point you to this thread the "solution" is to set the matrix of the BaseDraw so the drawing is done really near the camera. Be aware you can have issue with the clipping functions.
              hope this help.
                hello,
                setting the matrix to screen seems to work.
                Draw multiple text From Tag
                from c4d import plugins, utils, bitmaps, gui
                # Be sure to use a unique ID obtained from www.plugincafe.com
                PLUGIN_ID = 1052927
                class TDRAW_EXAMPLE(c4d.plugins.TagData):
                        # Returns if object is not a polygon object
                        if not op.IsInstanceOf(c4d.Opolygon):
                        # Retrieves the Object Matrix
                        opMg = op.GetMg()
                        # Retrieves All Points
                        points = op.GetAllPoints()
                        # Retrieves Global Coordinates
                        points = [opMg * p for p in points]
                        # From world to screen Coordinates (in another array)
                        screenPoints  =  [ bd.WS(p) for p in points  ]
                        # Prepares the dictionary for the draw multipleHUDText Draw Point Coordinates (world space) at screenPoint Position.
                        value =  [ { "_txt" : "point " + str(i) + " " + str(pos[0]) , "_position" : pos[1]  }    for i, pos in enumerate(zip(points, screenPoints)) ]
                        # Sets the matrix to screen space
                        bd.SetMatrix_Screen()
                        # Enables depth buffer.
                        bd.SetDepth(True)
                        # Draws points indices at point coordinates
                        bd.DrawMultipleHUDText(value)
                    def Execute(self, tag, doc, op, bt, priority, flags):
                        return c4d.EXECUTIONRESULT_OK
                    # Register the tag
                    c4d.plugins.RegisterTagPlugin(id=PLUGIN_ID,
                                                  str="Tag that draw on viewport",
                                                  info=c4d.TAG_EXPRESSION | c4d.TAG_VISIBLE,
                                                  g=TDRAW_EXAMPLE,
                                                  description="tdrawexample",
                                                  icon=None)
                tdrawexample.h
                #ifndef __TDRAWEXAMPLE_H__
                #define __TDRAWEXAMPLE_H__
                enum
                #endif // __pc11519_H__
                tdrawexample.res
                CONTAINER tdrawexample
                	NAME tdrawexample;
                	INCLUDE Obase;
                    GROUP ID_OBJECTPROPERTIES
                tdrawexample.str
                STRINGTABLE tdrawexample
                	tdrawexample								"Draw on viewport from tag";
                c4d_symbol.h
                enum
                    // End of symbol definition
                    _DUMMY_ELEMENT_
                  merkvilson
                  OMG! You just wrote the entire plugin for my silly question. 😱
                  Thank You!!! 💙
                  I have only one question.
                  Why did you use
                  Draw(self, op, drawpass, bd, bh)
                  instead of
                  will not drawpass be treated as op and op as a tag?
                    Manuel @merkvilson
                    well,
                    @merkvilson cause i started from an old ObjectData project and i didn't changed the signature xD
                    And exact, the name changed but not the object of course.
                    so, now you don't even need to retrieve the object from the tag 🙂 I've updated the code.
                    (always refresh your mind before starting another project ^^)
                    cheers
                      merkvilson
                      OK. Now I get it. 👌
                      Thank you very much! I really appreciate what you've done. 😁
                      Have a good day! 💙
                      -Merk
