    R20 Alembic Export Crash
    5 Posts 3 Posters 1.7k Views 2 Watching
    • D Offline
      dev-vfxboat
      I'm trying to use the ExportAlembic.py example in Cinema 4D R20 but the application crashes.
      The same example works in R19.
      Doing it manually via File > Export... > Alembic (*.abc) does work.
      Tried in both Windows 10 and macOS.
      While in macOs the crash reporter makes a log, in Windows, the applications freezes with "Preparing Project for Export" in the status bar.
        Hi @dev-vfxboat, first of all, welcome in the plugincafe community.
        This is a known bug and already fixed for SP2 (the next Service Pack). It's impacting both Python and C++.
        The workaround is to pass the flag c4d.SAVEDOCUMENTFLAGS_DIALOGSALLOWED to the SaveDocument function.
        Moreover, don't worry, but please make sure to read and use How to Post Questions (Especially about tagging system)
        • R Offline
          ryangordon
          This seems to still be happening in R20 for me and the workaround didn't seem to help. I don't see any mention of it in the release notes. This method succeeds (successful export) but Cinema freezes. I am on R20 059 (SP2 HF1) on Windows 10
          void ExampleDialog::exportObj(BaseObject* obj) {
          	AutoAlloc<BaseDocument> virtualDoc;
          	virtualDoc->InsertObject(obj, nullptr, nullptr);
          	String filepath = "D:\\Dropbox\\model.obj";
          	SaveDocument(virtualDoc, filepath, SAVEDOCUMENTFLAGS::DIALOGSALLOWED, 1030178);
            Hi @ryangordon, the Id (1030178) correspond to FORMAT_OBJ2EXPORT. So consider that both ABC and OBJ exporter is crashing in your case.
            Here I'm not able to reproduce with the next code
            AutoAlloc<BaseObject> obj{Ocube};
            String filepath = "C:\\Users\\m_adam\\Desktop\\model.obj";
            SaveDocument(virtualDoc, filepath, SAVEDOCUMENTFLAGS::DIALOGSALLOWED, FORMAT_OBJ2EXPORT);
            So I'm wondering if you really own the BaseObject pointer and if the issue is not there. Maybe the object is already inserted. If you can provide a full example it will help me to reproduce.
            • R Offline
              ryangordon
              Ah I think you're right - I take the object right from the document without a clone or anything. Thank you!
